| Preval Sprayer http://luthiersforum.com/forum/viewtopic.php?f=10101&t=46975 |
| Author: | Alex Kleon [ Tue Jan 05, 2016 10:28 am ] |
| Post subject: | Preval Sprayer |
I'm going to be using a couple of coats of shellac between grain fill and WB finish. I have a Fuji sprayer and two guns, but they are strictly for WB stain and finish. Does the Preval do a good enough job for a couple of coats? Thanks! Alex |
| Author: | phavriluk [ Tue Jan 05, 2016 10:53 am ] |
| Post subject: | Re: Preval Sprayer |
I found a Preval sprayer to be a tool I could do without. I'm sure that there are situations where the tool is a real help, but I haven't found such a situation yet. And I found the Preval sprayer I had threw out a really coarse splatter as 'spray'. I suspect a whole bunch of experimentation would be needed for me to find a good material/thinner proportion that sprayed anything like as nicely as a rattle can. Life is short and cleaning spray guns is a real PITA when small quantities need applying. Far more time setting up and breaking down than applying the finish. My opinion is to use rattle-cans whenever possible. No waste, no setup time, no cleanup time or mess, no drying-out of partial cans. I found them cheap at the price and a big timesaver. |
| Author: | kencierp [ Tue Jan 05, 2016 11:13 am ] |
Totally agree with Peter -- as been said before "not how you put it on, its what you end up leaving on" that really count. Rattle cans for me as well. |
| Author: | Heath Blair [ Tue Jan 05, 2016 12:36 pm ] |
I have to ask, why not just wipe on the shellac? |
| Author: | Alex Kleon [ Tue Jan 05, 2016 1:52 pm ] |
I don't want to use rattle can shellac as the quality and colour are not what I want to use. I know that I can wipe, pad or brush the shellac. My intention is not to finish my guitar with a Preval sprayer, I'll be using my hvlp to do that, just to spray a couple of shellac coats. Just wondering if the Preval can do the job. If it won't, I'll just apply the shellac by other means. Alex |
| Author: | Mike_P [ Tue Jan 05, 2016 5:44 pm ] |
good enough is relative...I've found that with experimentation I can get almost as good of a finish as with my Binks Mach1-SL... that being said, I've only used one a few times for in the field touch up work or for spraying 1' square panels as samples and did so just because setting up, breaking down and cleaning for such a small thing was unwarranted... overthinning is required from memory, and I think you should have at least 2 charges to do a couple of coats on a guitar... all things considered you might be far better off buying a cheapo gun from Harbor Freight... |
| Author: | Rod True [ Tue Jan 05, 2016 5:57 pm ] |
I use to use a $30 touch up gun for spraying shellac. It worked very well. I'd go that route vs a preval. Sent from my iPhone using Tapatalk |
| Author: | Clay S. [ Tue Jan 05, 2016 6:19 pm ] |
HF sells a jamb gun for $13 and a cheap regulator for another $4. They actually work pretty well. They also sell a detail gun for about the same price. It doesn't put out as much material but might be good for what you want plus touch up work. |
| Author: | Glen H [ Tue Jan 05, 2016 6:48 pm ] |
I found a preval type sprayer - where you could fill the cup with whatever and aerosol spray - at a paint store one time that worked like a dream. It had a handle with an adjustable nozzle. It sprayed very well. I don't remember the brand but was about 8 bucks with 1 aerosol charge. The preval is a piece of junk IMO. |
| Author: | Alex Kleon [ Tue Jan 05, 2016 6:59 pm ] |
Seems like the consensus is the Preval isn't worth the $9. I'll just wipe or brush the shellac, or maybe use my old Wagner conversion gun for non-waterbase finishes. Thanks for the help! Alex |
