First time finishing?
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=47422
Author:  dertien616 [ Tue Mar 08, 2016 11:37 pm ]
Post subject:  First time finishing?
Just going to start getting the supplies for finishing my first guitar. I was going to order z-poxy and cardinal lacquer and thinner from lmii. I will be spraying threw an hvlp gun. Do I need a sealer to or is the z-poxy used as the pore filler And sealer. Also I seen on there website you should do a coat of unwaxed shellac between the z-poxy and top coat. So I'm a little confused on what steps I should take and products I will all need.
Author:  B. Howard [ Wed Mar 09, 2016 7:05 am ]
Post subject:  Re: First time finishing?
The z-poxy can be a sealer as well as a filler. Depends on how you use it. If you leave a thin coat covering all the wood it will act as a sealer. If you sand it back so it just fills the pores you will need the sealer that goes with the cardinal lacquer.
Author:  dertien616 [ Wed Mar 09, 2016 12:25 pm ]
Should I do a coat of shellac between the z poxy and lacquer?
Author:  Joe Beaver [ Wed Mar 09, 2016 8:20 pm ]
No shellac between zpoxy and cardinal for me. I do use their vinyl sealer over the zpoxy but when I did a test panel I really couldn't see much difference. I'm thinkling shellac would be a mistake.
Author:  Ben-Had [ Wed Mar 09, 2016 11:31 pm ]
I use all the Cardinal products -pore filler, sealer, nitro and thinner when necessary.
I spray sealer, pore fill, seal, then apply the nitro. I thin my sealer 50/50.
Author:  kencierp [ Thu Mar 10, 2016 9:27 am ]
I'd check with Pacer (maker's of Zpoxy) before using shellac on or under Zpoxy there are reports of problems. On the other hand I have personally contacted them regarding nitro lacquer and it is fully compatible as the nitro will etch and chemically bond --- so there is really no need for shellac at all. Since the nitro vinyl sealers have the same solvents as the top coats I am sure they would work fine as a "tweener" -- but again really not necessary. Some feel the added flexibility in the vinyl sealer has long term benefits.
