| Martin 00028 EC specifications http://luthiersforum.com/forum/viewtopic.php?f=10101&t=48047 |
| Author: | Chuck [ Tue Jul 19, 2016 10:10 pm ] |
| Post subject: | Martin 00028 EC specifications |
I tired using the search on the site but I didn't come up with the specifications for the Martin 00028 EC. I am wondering about the top and back radius. I am thinking of making some radius dishes and thought that while I was doing the 15 inch, 25 inch and the 30 inch I would make a couple for the 000 also. However I have not been able to come up with the radius that would be needed. Anyone know where I can get the specification for the Martin 00028EC? Thanks for any help you can provide. Chuck |
| Author: | kencierp [ Tue Jul 19, 2016 11:35 pm ] |
| Post subject: | Re: Martin 00028 EC specifications |
Martin sound board bracing contour is 52' (X and tone bars) and the backs are 15' --- If you contact the factory they'll proudly tell you they make "flat top guitars" The top of the rim is sanded flat with a 1.3 degree of slope from the sound hole to the neck block. Pictures of the rim sander can be seen here in this article. http://www.kennethmichaelguitars.com/neckangle.html |
| Author: | klooker [ Wed Jul 20, 2016 6:58 am ] |
If I'm not mistaken, Martin also glues their braces to the top on a flat surface - no dish or concave fixture. |
| Author: | bluescreek [ Wed Jul 20, 2016 8:06 am ] |
the tone bars on Martin are flat the only radiused braces are the 2 X and the Transverse . The neck is a mod Vee they use a fine herringbone Squares and diamond fretboard Fine herringbone rosette |
| Author: | kencierp [ Wed Jul 20, 2016 9:36 am ] |
Update from the Martin factory Hi Ken, That is a top bracing fixture. The plate is flat with a 1deg. angle that starts at the back of the number 1 brace just above the soundhole and continues to the top or front block. |
