| Another nitro question... http://luthiersforum.com/forum/viewtopic.php?f=10101&t=48232 |
| Author: | meddlingfool [ Fri Sep 02, 2016 7:37 pm ] |
| Post subject: | Another nitro question... |
This is my first with nitro, so I'm unfamiliar with some of the properties... Drilling the tuners holes, there was some slight delaying of the finish at the very edge, which is to be expected I think. However, I had expected nitro to be a more flexible film like texture, whereas the chips are breaking into tiny crystals, like I expect from UV cure poly. Is that normal? |
| Author: | Woodie G [ Sat Sep 03, 2016 6:50 am ] |
| Post subject: | Re: Another nitro question... |
One option is to pre-drill the holes and clear them after finishing with reamers...much less lift on free edges. Well dried lacquer is definitely more brittle than something like Enduro-Var, that has to really be mishandled to separate. |
| Author: | B. Howard [ Sat Sep 03, 2016 7:55 am ] |
meddlingfool wrote: This is my first with nitro, so I'm unfamiliar with some of the properties... Drilling the tuners holes, there was some slight delaying of the finish at the very edge, which is to be expected I think. However, I had expected nitro to be a more flexible film like texture, whereas the chips are breaking into tiny crystals, like I expect from UV cure poly. Is that normal? Yep. |
| Author: | meddlingfool [ Sat Sep 03, 2016 12:45 pm ] |
Great, thanks, that eases my mind considerably. |
| Author: | Nils [ Sat Sep 03, 2016 1:08 pm ] |
I saw this on the guild instagram the other day...https://www.instagram.com/p/BJ2-MfbjEvr ... tars&hl=en Looks like a good solution to me. |
| Author: | Nils [ Sat Sep 03, 2016 1:10 pm ] |
Ohh, sorry, I read your post too quickly...I've always pre-drilled. |
| Author: | meddlingfool [ Sat Sep 03, 2016 3:18 pm ] |
I've always found it easier to buff the headstock without holes. The holes have a tendency to catch the compound leaving an unpolished but underneath, or to burn through. |
| Author: | Clay S. [ Sun Sep 04, 2016 8:37 am ] |
"The holes have a tendency to catch the compound leaving an unpolished but underneath, or to burn through." Slightly chamfering the holes may help the lacquer "wrap around" a bit and reduce that tendency. |
| Author: | meddlingfool [ Sat Sep 10, 2016 5:38 pm ] |
Excellent idea. |
| Author: | philosofriend [ Mon Sep 12, 2016 7:52 am ] |
The brittleness of nitro is believed to be part of why it lets the treble of the guitar sing through. Part of the beauty of old traditional guitars is the look of the little chips. Some nitro comes with more plasticizers mixed in, which makes it softer and tougher. This is a reason to stick with one brand of finish as you learn how to deal with it. I add a drop of castor oil to an ounce of mixed nitro for a tough model airplane finish, I suppose you could use that for a certain part of a guitar where you were worried about chipping. One of the best things about nitro is that you can invisibly fix just about anything that goes wrong as you are learning how to use it. |
