Another addition to my bench http://luthiersforum.com/forum/viewtopic.php?f=10101&t=48341 |
Author: | Rod True [ Thu Sep 29, 2016 10:29 pm ] |
Post subject: | Another addition to my bench |
I've wanted a cradle to hold guitar bodies while binding. So I made this one. Simple, doesn't need total height adjusting like a cradle being used for some binding jigs. I put it on a post so I can turn it but still keep the cradle in one spot on the bench. Will be good for installing bindings as well as scraping. ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
Author: | meddlingfool [ Fri Sep 30, 2016 12:11 am ] |
Post subject: | Re: Another addition to my bench |
Looks handy but I would mount it way closer to the front. That looks like back pain in the making... |
Author: | Rod True [ Fri Sep 30, 2016 1:01 am ] |
When I rotate to the lower bout it's only 1/4" from the bench edge.... |
Author: | meddlingfool [ Fri Sep 30, 2016 2:42 am ] |
You know what works for you! |
Author: | edstrummer [ Fri Sep 30, 2016 7:08 am ] |
Rod True wrote: I've wanted a cradle to hold guitar bodies while binding. So I made this one. Simple, doesn't need total height adjusting like a cradle being used for some binding jigs. I put it on a post so I can turn it but still keep the cradle in one spot on the bench. Will be good for installing bindings as well as scraping. ![]() ![]() ![]() Sent from my iPhone using Tapatalk Looks very useful. Nice job. Sent from my SM-T230NU using Tapatalk |
Author: | bcombs510 [ Fri Sep 30, 2016 7:34 am ] |
That's a great idea. I have the carrier like what you have there that I use for the binding cutting jig. I may put a removable pin in that and use it like your idea here. Thanks for sharing it. Right now I'm using a cork lined L shaped board with a catch that catches the front edge of the bench. It doesn't spin though. This is better. Thanks! Brad |
Author: | jfmckenna [ Fri Sep 30, 2016 8:21 am ] |
I've been needing to build something like that for a while. I do bindings differently but it could be very useful for other tasks as well. |
Author: | sdsollod [ Fri Sep 30, 2016 8:42 am ] |
Great idea! |
Author: | DannyV [ Fri Sep 30, 2016 9:56 am ] |
Nice! I use the same cradle I use for cutting bindings. It looks similar. Sweet looking guitar Rod. Aussie Blackwood? |
Author: | Rod True [ Fri Sep 30, 2016 1:35 pm ] |
My binding set up use to be this However I'm moved to the Larrivee style from CLS. So I lost the cradle when I sold my binding jig set up. I always used the cradle when I was installing the binding but found it a bit difficult to get from one side over to the other, thus the idea to make a basic cradle on a stick ![]() Ken, I always like seeing your simple solutions to things......keep it up. |
Author: | Rod True [ Fri Sep 30, 2016 1:36 pm ] |
DannyV wrote: Nice! I use the same cradle I use for cutting bindings. It looks similar. Sweet looking guitar Rod. Aussie Blackwood? Yes, 3rd guitar I'll have made from Aussie Blackwood. And Thanks. Looking forward to getting this one finished, hope before Christmas. |
