Hand sawing to plates http://luthiersforum.com/forum/viewtopic.php?f=10101&t=48528 |
Author: | gxs [ Sat Nov 12, 2016 5:55 pm ] |
Post subject: | Hand sawing to plates |
Hi All. I have a 1" x 10" Western Hemlock board that I am thinking about making into some top plates. As a hobbyist I like to try new things (hemlock) so I thought I'd try hand cutting the plates (vs. Band or Table saw). Any suggestions for making a jig to do this with a hand saw? I saw a picture of the Lyon Healy / Regal plant from the turn of the 20th Century, and it looked like they had a slotted box in which they stood the plate material , and a two man hand saw. Keeping it with the theme of "olde tymey" I want to use my grandfather's WWI era hand saw, which I recently sharpened. This could be fun, or a crime against nature, TBD. Regards, GS |
Author: | ernie [ Sat Nov 12, 2016 7:06 pm ] |
Post subject: | Re: Hand sawing to plates |
FWIW . I resawed vln plates in maple wood using a large beam saw, basically a 1.5in wide blade 5 ft long with 2 straight handles. I got the blade from suffolk machinery.Tensioning is via a long wing nut it/s a t shape with 2 handles .I/ve also done it with a 28in 5 pt ripsaw or euro bowsaw that has a 1in blade traditional woodworker or highland hardware sells these euro saws. A large japanese ryoba ripsaw works well in softwoods , japan woodworker , woodcraft, etc. The problem with usa rip saws for ripping plates is they don/t track well because of the whippy blade . Hope this helps . THey do work for ripping e.g. taking a 2in slice off a 5in board |
Author: | Ruby50 [ Sat Nov 12, 2016 8:07 pm ] |
Here's a page out of Ruobo. A friend made one - ended up being a pretty heavy thing to keep it from moving around as you saw. Ed PS - your grandfather's saw better be filed for rip |
Author: | Clay S. [ Sun Nov 13, 2016 8:14 am ] |
To saw plates with a hand saw I would first cut the board to the maximum width needed for the instrument. I would then kerf both edges with the table saw blade raised as high as possible. The kerfs would act as a guide for the hand saw. This would allow you to use your grand dad's hand saw with out turning the endeavor into a "manhood" thing |
Author: | Bryan Bear [ Sun Nov 13, 2016 8:24 am ] |
As said, the saw better be filed for rip cuts but also very sharp and filed evenly so it tracks well. You don't say much about the saw, are the gullets deep enough for such a wide rip cut. There will be a lot of dwarf to remove from a 10" wide rip cut. . . I'' not saying don't do this, but you'all be manliest than I am when you are done |
Author: | ernie [ Sun Nov 13, 2016 9:01 am ] |
george I got the plans for making the beam saw from a book in the local library.They are fairly easy to make and you can use leftover wood scraps an bits of hardware. The blade stock can be purchased from suffolk machinery .The beam saw works quite quickly. But your wood should be mounted in a secure vice with at least 6 ft of empty space around you. Start with a cut at a 45 deg angle with the wood held upright, and mark your wood all around so you don/t veer off your cut line . Practice on scrap first !! Roy Underhill ![]() ![]() |
Author: | gregorio [ Sun Nov 13, 2016 12:44 pm ] |
Here is Tom, he is awesome! https://m.youtube.com/watch?v=OtmswWZ4Lvo |
Author: | gxs [ Wed Nov 16, 2016 12:23 am ] |
Bryan Bear wrote: As said, the saw better be filed for rip cuts but also very sharp and filed evenly so it tracks well. You don't say much about the saw, are the gullets deep enough for such a wide rip cut. There will be a lot of dwarf to remove from a 10" wide rip cut. . . I'' not saying don't do this, but you'all be manliest than I am when you are done It is a rip saw. Six teeth per inch, and just sharpened, to your point though the gullets are not that deep, so it could take a while. Thanks GS |
Author: | gxs [ Wed Nov 16, 2016 12:26 am ] |
gregorio wrote: Ah, ya see what happens, now I am totally jonesin' for one of those kerfing planes. . . and darn it there are plans for it, and I can think of a bunch of uses for it. |
Author: | jfmckenna [ Wed Nov 16, 2016 11:28 am ] |
gregorio wrote: Ah yes! When I first saw this thread that is the video I was thinking of which I saw a while back, could not remember the guys name though. |
Author: | Bryan Bear [ Wed Nov 16, 2016 11:45 am ] |
gxs wrote: Bryan Bear wrote: As said, the saw better be filed for rip cuts but also very sharp and filed evenly so it tracks well. You don't say much about the saw, are the gullets deep enough for such a wide rip cut. There will be a lot of dwarf to remove from a 10" wide rip cut. . . I'' not saying don't do this, but you'all be manliest than I am when you are done It is a rip saw. Six teeth per inch, and just sharpened, to your point though the gullets are not that deep, so it could take a while. Thanks GS Yikes! I hate reading quotes from me that demonstrate how terrible my cell phone posts are. . . really, how terrible my proofreading is ![]() That was swarf not dwarf, I'm not I", you'll be manlier than I. . . ![]() |
Author: | Ruby50 [ Thu Nov 17, 2016 5:57 am ] |
Six teeth per inch will be fun. 4-1/2 would be my guess for that much wood. Ed |
Author: | unkabob [ Mon Nov 21, 2016 5:44 pm ] |
I once considered using a reciprocating saw (sawzal) with bearings as guides mounted horizontally. Just a thought. Bob ![]() |
Author: | JSDenvir [ Mon Nov 21, 2016 5:51 pm ] |
Bryan Bear wrote: gxs wrote: Bryan Bear wrote: As said, the saw better be filed for rip cuts but also very sharp and filed evenly so it tracks well. You don't say much about the saw, are the gullets deep enough for such a wide rip cut. There will be a lot of dwarf to remove from a 10" wide rip cut. . . I'' not saying don't do this, but you'all be manliest than I am when you are done It is a rip saw. Six teeth per inch, and just sharpened, to your point though the gullets are not that deep, so it could take a while. Thanks GS Yikes! I hate reading quotes from me that demonstrate how terrible my cell phone posts are. . . really, how terrible my proofreading is ![]() That was swarf not dwarf, I'm not I", you'll be manlier than I. . . ![]() Thanks for the clarification, I was gonna inquire about your dwarf problem ![]() Unless, of course, dwarves are the new goats. Steve |
Author: | gerry [ Sun Nov 27, 2016 1:21 pm ] |
I've done it... pretty much as Clay S. described above. As I moved down the cut I put shims into the slot and moved the clamps to above the saw. Attachment: ripsaw2.jpg
