| Hesh upper bout flattening procedure clarification http://luthiersforum.com/forum/viewtopic.php?f=10101&t=48996 |
| Author: | talladam [ Sun Feb 12, 2017 6:07 pm ] |
| Post subject: | Hesh upper bout flattening procedure clarification |
Hi all! I don't often ask questions here since most questions seem to already have been answered, but I am confused about Hesh's tutorial for flattening the upper bout to match the neck angle. http://www.luthiersforum.com/forum/viewtopic.php?f=10117&t=25931 Everything is very clear, except Hesh is using a 25' radius top and mine will be 28'. Will this make enough of a difference to have to change the size of the 1/8 " shim? Also, does the body length of the guitar factor in here? I guess the angle will be different for a shorter guitar. The only solution I can think of is to put a shim across the guitar body at the bridge position. It would have to be the amount that the soundboard is arched in the center of the body plus the height of the saddle ( 1/8"?) But maybe I am over thinking this. Can you offer any insight? Thanks. Adam |
| Author: | Hesh [ Sun Feb 12, 2017 6:47 pm ] |
| Post subject: | Re: Hesh upper bout flattening procedure clarification |
No, I've done it with 28' and other body shapes as well and think that I say that somewhere in the toot but it's been few years so I could be wrong abut that. It works well with the same shim for 28'. I suspect that you are thinking that flattening the upper is setting the neck angle, two different operations and the flattening the upper bout process does not have to be overly precise. We are simply removing the dome from the top in the fret board extension region. |
| Author: | talladam [ Sun Feb 12, 2017 7:03 pm ] |
Thanks Hesh. I was figuring that the upper bout had to be at the same angle as the neck, because diverging neck angle and soundboard (the angle of which is set by the flattening of the upper bout) created a gap. Sounds like I am getting a bit too worried about it. |
| Author: | Hesh [ Sun Feb 12, 2017 7:07 pm ] |
No problem Adam. When we fret the extension it wants to take a dive downward as well from fret tang compression. The amount of fall-away is not critical and you can tweak it with the frets too if need be. Flattening the upper bout is related to another toot I did about setting neck angles. The neck angle one is where we take dynamic measurements and have to be far more precise. |
