| Upside down truss rod http://luthiersforum.com/forum/viewtopic.php?f=10101&t=49123 |
| Author: | Dylan Maloney [ Mon Mar 13, 2017 2:57 pm ] |
| Post subject: | Upside down truss rod |
I am new to the forum, but have built 4 guitars, working on 5 and 6 now. I just glued the fretboards on and realized i made a terrible mistake (twice), the truss rods are upside down. I feel very disheartened, and am wondering what the options are. The slots are too tight to pull the rods out, tried that already. I thought about arcing the board under back tension to compensate for the future tension, and decided thats asking for trouble, and probably creating more problems in the future. Now i'm thinking the best option will be to remove the unslotted fretboards. One has been glued for a full day, the other for 4 hours. Im going to borrow an iron and try to get the fresher one off, but i may have to plane down and start over. Anyone have any advice? Thanks in advance |
| Author: | johnparchem [ Mon Mar 13, 2017 3:14 pm ] |
| Post subject: | Re: Upside down truss rod |
Be patient with heat and a thin blade, like a frosting knife the fretboard will come right off. No need to plane, even it has been glued for 10 years. |
| Author: | kencierp [ Mon Mar 13, 2017 3:58 pm ] |
I agree wtih John - a little heat and it will come off easily, but don't be surprised if it warps badly. Many/most of today's store bought TR's are two way just wondering what you have there? |
| Author: | Colin North [ Mon Mar 13, 2017 4:01 pm ] |
Dylan Maloney wrote: I am new to the forum, but have built 4 guitars, working on 5 and 6 now. I just glued the fretboards on and realized i made a terrible mistake (twice), the truss rods are upside down. I feel very disheartened, and am wondering what the options are. The slots are too tight to pull the rods out, tried that already. I thought about arcing the board under back tension to compensate for the future tension, and decided thats asking for trouble, and probably creating more problems in the future. Now i'm thinking the best option will be to remove the unslotted fretboards. One has been glued for a full day, the other for 4 hours. Im going to borrow an iron and try to get the fresher one off, but i may have to plane down and start over. Anyone have any advice? Thanks in advance Some tips on removing a fretboard in this http://www.stewmac.com/How-To/Trade_Secrets/Fixing_a_warped_neck_with_carbon_fiber.html?lac_guid=daa92db7-f396-e611-80ce-ecb1d775572a&utm_campaign=ts0273&utm_medium=email&utm_source=newsletter&utm_content=ts0273_C_20161020 |
| Author: | Dylan Maloney [ Mon Mar 13, 2017 4:08 pm ] |
Thanks for the quick responses! They are one way rods from lmii. Everything I've learned thus far was working with a luthier in Xalapa, Mexico, these are the second and third builds without his instruction. It's been and interesting ride translating the knowledge I learned from him into English and setting up my own shop piece by piece. I'm glad there is a community of builders to get support and advice from. Thanks again! |
| Author: | Dylan Maloney [ Mon Mar 13, 2017 5:39 pm ] |
Update: Hot iron, patience, and a thin spatula, they popped right off! They are pretty warped and one was staring to split a little at the ends, but that's a minor setback relatively. |
| Author: | Colin North [ Mon Mar 13, 2017 5:50 pm ] |
| Author: | bcombs510 [ Mon Mar 13, 2017 8:37 pm ] |
Nice job. Glad it worked. Sent from my iPhone using Tapatalk |
| Author: | BobHowell [ Tue Mar 14, 2017 4:45 am ] |
I'm wondering, as I read this, about the distortion to the fret board. Can it be corrected or is it ruined. |
| Author: | Colin North [ Tue Mar 14, 2017 4:48 am ] |
BobHowell wrote: I'm wondering, as I read this, about the distortion to the fret board. Can it be corrected or is it ruined. Personally I doubt it. |
| Author: | meddlingfool [ Tue Mar 14, 2017 10:51 am ] |
Probably meaning, 'I doubt it can be corrected'. I would not risk trying to reuse a distorted fingerboard. |
| Author: | Cal Maier [ Tue Mar 14, 2017 5:26 pm ] |
Pardon my ignorance, but why would you want to slot your fingerboards after they have been glued on the neck instead of slotting before they are installed? Seems like a lot more work slotting after than slotting before, and possibly not as accurate either. Cal |
| Author: | Craig Bumgarner [ Wed Mar 15, 2017 9:09 am ] |
If it is bowed, I'd try to straighten the fingerboard by supporting the ends and weigh it in the middle. if it is twisted, this is not good and likely a sign that it wasn't such a great fingerboard to start with. I'd pitch it, you are better off discovering this now than having the it twist later on. |
| Author: | Mike OMelia [ Thu Mar 16, 2017 10:22 pm ] |
How did you do that? With rounded edges and all? |
