What thickness slats do people use for bending?
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=49960
Author:  Pmaj7 [ Thu Nov 16, 2017 12:05 pm ]
Post subject:  What thickness slats do people use for bending?
Stainless and spring. I have only used .015" SS and wondered if thicker would give more support?
Author:  bluescreek [ Thu Nov 16, 2017 12:07 pm ]
Post subject:  Re: What thickness slats do people use for bending?
much depends on the temper . Many buy the shim stock that is non tempered and will bend I use the tempered stainless.
.015 is plenty for support .
Author:  Terence Kennedy [ Thu Nov 16, 2017 1:09 pm ]
I've been using blue tempered shim stock at 0.010 with no problem for a long time. Wrapped in foil plus the brown wrapping paper.
Author:  Mike OMelia [ Sun Nov 19, 2017 2:15 pm ]
I got mine from John, perfectly sized for the fox bender. If what I have is what he is selling now, they do bend some, easily reshaped, but not that true blue spring steel. I've always been a bit wary of that stuff. What I use now will pop if tape comes undone (after bending), but not bad as to worry me. I have never had a support issue with these.
Author:  Mike OMelia [ Sun Nov 19, 2017 2:16 pm ]
What do you use the foil for?
Author:  Terence Kennedy [ Sun Nov 19, 2017 3:16 pm ]
To make sure the slats don’t discolor the wood. Might not be necessary with the paper but i’ve been doing it so long I just keep doing it. I just wrap it around the slat and secure with binding tape. The same foil has been on my slats quite a while.
Author:  Clay S. [ Sun Nov 19, 2017 7:01 pm ]
I use strips of Formica for slats. They do eventually take a "set" but they are semi disposable. I don't use paper or foil and keep the blanket to the inside of the work piece so any minor scorching that might occur is on the inside.
Author:  Haans [ Sun Nov 19, 2017 7:19 pm ]
I just bought John Hall's whole setup. It works, the thermostat is reliable and just made my own bending forms.
Looking back on it all, I probably should have ordered a third slat, but it worked very well, Only problems I had were of my own making.
Author:  Colin North [ Sun May 13, 2018 7:29 am ]
This "Frank Barraza" bot or whatver is a bit of a pain in the proverbial @/.'*.
