Good tuts for motorized sanding dish station?
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=50337
Page 1 of 2
Author:  meddlingfool [ Wed Feb 21, 2018 8:49 pm ]
Post subject:  Good tuts for motorized sanding dish station?
One grows weary of driving the bus...
Author:  meddlingfool [ Wed Feb 21, 2018 8:50 pm ]
Post subject:  Re: Good tuts for motorized sanding dish station?
I would have thought YouTube would be filled but no...
Author:  SnowManSnow [ Wed Feb 21, 2018 9:11 pm ]
I’ll seen this somewhere.
It wasn’t crazy complicated.... was just a motor on a rheostat connected to the dish:/
I want to say there was a way the guy referenced the mold tonthe center of the dish to keep it stable.... but I don’t remember how it went.
I’ll keep eyes open
Wouldn’t want one to get weary:)
Author:  SnowManSnow [ Wed Feb 21, 2018 9:13 pm ]
Here’s what I saw..
I giggle when I see it for some reason... like I’m expecting it to turn into a disk decapitator or something haha
https://youtu.be/Hxz13mO7Hnw
Author:  meddlingfool [ Wed Feb 21, 2018 9:38 pm ]
I've seen that. I'd prefer something about less menacing...
Author:  rlrhett [ Wed Feb 21, 2018 9:39 pm ]
That is crazy! I wouldn't want to be in the same room as that once it is up to speed.
I'm in the process of trying to make one relatively cheaply. I've ordered some parts and will report back if it works OK. The issue is the motor. I'm trying to use a relatively inexpensive 24V motor geared down to 100rpm, but don't know if it will have enough juice. I'll post here once I've got it built.
Author:  AndyB [ Wed Feb 21, 2018 9:40 pm ]
Charles Fox came up with it. It's a dish with a shaft which has a pulley, and is driven by a belt off a motor. Some thin plywood sides along the perimeter. Hook up some dust collection as your please.
Andy
Author:  SnowManSnow [ Wed Feb 21, 2018 9:44 pm ]
My thoughts too....
My eyes get big when it speeds up haha
Author:  Ben-Had [ Wed Feb 21, 2018 11:39 pm ]
PM sent
Author:  doncaparker [ Thu Feb 22, 2018 7:36 am ]
Check out this thread, and the other thread I reference in this thread:
http://www.luthiersforum.com/forum/view ... rized+dish
Short version:
Buy a cheap Harbor Freight belt/disk sander and harvest its 1750 rpm motor, with its attached pulley, power cord and switch.
Buy some bearings, belts, shafts, and pulleys, such that you can have the motor pulley drive a large pulley on a shaft, and that same shaft has a small pulley. That small pulley drives a large pulley on the shaft that will drive the dish. This reduces the rpm at the dish to the desired level.
Attach a sprocket, or a spare pulley, to the end of the shaft that will drive the dish. Install an off center pin in that sprocket/pulley. Put a center hole in your dish that is the right size for accepting the drive shaft, and an off center hole to accept the off center drive pin.
Install rubber casters in a circle underneath the dish, a few inches from its outer edge.
Cheap, easy, and safe. No more driving the bus.
Author:  Michaeldc [ Thu Feb 22, 2018 9:43 am ]
Have you got access to a cnc with at least a 36" X 36" capacity? I will happily send the Vcarve files if you are interested in making one like mine. You will obviously need to own Vcarve to open the file. I will say it's WAY faster than driving the bus. I'm able to cut a wedge body back radius in about 90 seconds. The top radius in about 20. I have maybe $550US in parts into mine though that includes a set of dishes from Canadian Luthier Supply. Not cheep, but good!
M
Author:  dberkowitz [ Thu Feb 22, 2018 9:50 am ]
Most dish Sanders are designed to be run at only 150 RPM. Hardly a breakneck pace.
Author:  rlrhett [ Thu Feb 22, 2018 9:56 am ]
Did you intend to respond to my post specifically? I’m not sure what you are trying to say.
Author:  meddlingfool [ Thu Feb 22, 2018 11:26 am ]
Michael, are you saying you have plans for parts to make one on a CNC?
Author:  Clay S. [ Thu Feb 22, 2018 11:40 am ]
"I've seen that. I'd prefer something about less menacing..."
If you can find an old food processor you can mount a dish on you can have a multi speed unit that stores away in a cabinet. This one is working out pretty well. No menace here...
Author:  Aaron O [ Thu Feb 22, 2018 4:02 pm ]
Find a used potter's wheel. My friend is a raku artist, and that's the first thing I thought of when I watched him throw a pot. He sold one of his old ones to a local shop, that uses it for exactly what this thread is about.
Author:  Michaeldc [ Thu Feb 22, 2018 4:17 pm ]
Yes
Author:  Shane Neifer [ Thu Feb 22, 2018 4:39 pm ]
I built my current one with a reduction gear from Princess Auto. I did get carried away and had a very nice plate manufactured (machined) that cost me about $750. So all in my sander cost about $1000. You can make one WAY cheaper than that but the reduction gear is only about $140 new and probably available from a fish plant or shipyard around the waterfront for next to nothing. I will send you a picture of mine for reference though.
Author:  meddlingfool [ Thu Feb 22, 2018 4:56 pm ]
That would be awesome!
Author:  Michaeldc [ Thu Feb 22, 2018 5:03 pm ]
It's gonna require some messin on your part. I'm happy to help out with info where I can. Imagine this with a 24" dish screwed to the backing plate. Someone with a metal lathe for a super basic operation would also be handy.
Author:  meddlingfool [ Thu Feb 22, 2018 7:05 pm ]
That looks very practical! Good job!
Author:  Michaeldc [ Thu Feb 22, 2018 10:29 pm ]
I'm at mt baker skiing for a few days. I'll send the file when I get home.
Author:  meddlingfool [ Fri Feb 23, 2018 2:11 am ]
No hurry, break a leg!
Author:  fingerstyle1978 [ Fri Feb 23, 2018 3:29 pm ]
I built mine out of a gear motor, mdf, a couple sprockets from Ebay and some cheap Ebay Chinese casters for the disk to ride along.
Author:  ernie [ Sat Feb 24, 2018 12:59 pm ]
Joey I/m frugal LOl do you have pics of your rig ? or some kind of diagram, I/ve been a DIY er since I was 13 haha thanks
