| Color for mahogany neck ? http://luthiersforum.com/forum/viewtopic.php?f=10101&t=51580 |
| Author: | 6string [ Fri Feb 08, 2019 7:00 pm ] |
| Post subject: | Color for mahogany neck ? |
I applied a couple of coats of tru oil to the mahogany neck but it’s a lot lighter ( natural ) in color than I would like. What is the preferred method and or product that should be used to color the mahogany a medium dark color? |
| Author: | Clay S. [ Fri Feb 08, 2019 7:53 pm ] |
| Post subject: | Re: Color for mahogany neck ? |
Potassium permanganate is an oxidizer that will darken mahogany (and many other woods). It can be found at some pool supply places. |
| Author: | Freeman [ Fri Feb 08, 2019 8:21 pm ] |
Every time I use a mahogany neck with rosewood I stain it to be a close match. I use StewMac Colortone dyes dissolved in alcohol. Some pore fillers will color the wood also. Attachment: IMG_2882.JPG I wanted to match this neck to a cocobolo body Attachment: IMG_4021.JPG Attachment: IMG_4378.JPG
| Author: | J De Rocher [ Sat Feb 09, 2019 1:42 am ] |
That color match to the cocobolo looks great. |
| Author: | John Arnold [ Mon Feb 11, 2019 8:06 pm ] |
Brown mahogany aniline dye, mostly. |
| Author: | B. Howard [ Tue Feb 12, 2019 8:24 am ] |
Well now that it has oil on it your options are limited unless you sand back to bare wood. I always match mine with dye stain before I apply finish. |
| Author: | TimAllen [ Thu Feb 14, 2019 2:33 pm ] |
Like John Arnold, I usually use aniline dye. I use the type that's mixed with water. The neck shown below is dyed with Constantine's "brown mahogany" with a little Lockwood "red mahogany." Possibly this will work over a couple of coats of Tru-Oil (more on this in the last paragraph). Aniline is much more fade resistant than many dyes, but will the color will fade a bit if put in a bright sunny window for an extended period. The mahogany will darken a bit with age as that's happening; maybe that compensates. I've stained unsealed wood by applying oil-based pore filler. As shown in Terence's photo, this works well and gives a nice even look. As Mr. Guthrie alludes to in another thread, some think this look is "muddy" because it isn't as transparent as a dye. I understand Martin used this method to color mahogany necks and it is regarded as traditional. I have a D-35 with a semi-opaque neck finish and I notice that it puts the color of the neck in the background and foregrounds the striking color of the BRW back and sides. But for guitars I make I prefer a clearer look. A dilute solution of household lye dyes mahogany medium-dark reddish brown, and the color doesn't fade. I'm thinking of trying this. If you trust yourself to use drain cleaner and oven cleaner, I think you can use dilute dye to stain wood. (Tips: use gloves, and don't drink it.) If you use water-based aniline dye or lye in water, you need to raise the grain first with water and sand it back down, twice, and then seal with a 1 lb cut (very dilute) solution of shellac. Otherwise the end grain of the heel will get darker than the rest of the neck. Tru-Oil is a very dilute varnish, and--if you haven't already sanded it off--just 2 coats might function like a thin coat of shellac and allow the wood to absorb dye, and absorb it more evenly. If you have any mahogany scraps to test it on, it would be worth a try. |
| Author: | RaymundH [ Fri Feb 15, 2019 3:34 pm ] |
Have you tried using Winton oil colors with your Truoil? They are based solely in Linseed oil so a little dab in your finish will color your neck nicely. I used it for a neck and it worked great. I got the idea here: https://www.youtube.com/watch?v=eCMNqL5laEg I bought my tube at Michael's. |
