| Latest Build - Adi Spruce/Mahogany Back&Sides http://luthiersforum.com/forum/viewtopic.php?f=10101&t=52316 |
| Author: | NJRiversguitars [ Thu Aug 29, 2019 7:55 pm ] |
| Post subject: | Latest Build - Adi Spruce/Mahogany Back&Sides |
![]() Sent from my iPhone using Tapatalk |
| Author: | NJRiversguitars [ Thu Aug 29, 2019 7:56 pm ] |
| Post subject: | Re: Latest Build - Adi Spruce/Mahogany Back&Sides |
| Author: | Glen H [ Thu Aug 29, 2019 7:59 pm ] |
Wow. It takes more talent than I have to do that inlay in spruce. Hats off to you! |
| Author: | NJRiversguitars [ Thu Aug 29, 2019 8:02 pm ] |
Glen H wrote: Wow. It takes more talent than I have to do that inlay in spruce. Hats off to you! Thank You so much! Means a lot! Been working hard to get my inlays just right and I found that segmented rosettes are my favorite! Sent from my iPhone using Tapatalk |
| Author: | jshelton [ Thu Aug 29, 2019 8:20 pm ] |
I really like your inlays, bindings, etc. but what impresses me the most is the shape. Your guitar is very graceful, I particularly like the nice round bottom (lower bout) with no sign of the ubiquitous flat spot. |
| Author: | NJRiversguitars [ Thu Aug 29, 2019 8:25 pm ] |
jshelton wrote: I really like your inlays, bindings, etc. but what impresses me the most is the shape. Your guitar is very graceful, I particularly like the nice round bottom (lower bout) with no sign of the ubiquitous flat spot. Thank you! The Shape was designed By my Mentor Tom Thiel. He took about 5 years rounding the shape so the whole instrument would have no straight lines. For the past 7 years these shapes have only been a drawing and now I have brought them to life! But of course I put my own twist on his shape! Sent from my iPhone using Tapatalk |
| Author: | jfmckenna [ Fri Aug 30, 2019 7:19 am ] |
Great looking guitar and I do like that little mountain inlay on the fretboard. |
| Author: | Ruby50 [ Fri Aug 30, 2019 7:47 am ] |
Everything is beautiful on this one - the shape is great. How do you inlay the little white lines that form the mountains? Ed |
| Author: | NJRiversguitars [ Fri Aug 30, 2019 8:40 am ] |
Ruby50 wrote: Everything is beautiful on this one - the shape is great. How do you inlay the little white lines that form the mountains? Ed Hey Ed! What I do is first cut the channel with a Dremel and then I fill it with resigns and powder pigments! I have a 1mm Dremel bit that does the job nice! Sent from my iPhone using Tapatalk |
| Author: | Colin North [ Fri Aug 30, 2019 8:59 am ] |
I really like the whole thing, but the rosette tops it off. May ask for some details of how you go about the interrupted rosette? There's not a lot of info out there. |
| Author: | NJRiversguitars [ Fri Aug 30, 2019 12:28 pm ] |
Colin North wrote: I really like the whole thing, but the rosette tops it off. May ask for some details of how you go about the interrupted rosette? There's not a lot of info out there. Hey Colin! Thanks for the compliments! The way I do my rosettes is I have made my self a cheat sheet of different angles in a circle that I like and use it as a guide to mark where one segment of the rosette starts and where it ends! Here’s a photo of the circle sheet I use! ![]() Sent from my iPhone using Tapatalk |
| Author: | NJRiversguitars [ Fri Aug 30, 2019 12:29 pm ] |
Colin North wrote: I really like the whole thing, but the rosette tops it off. May ask for some details of how you go about the interrupted rosette? There's not a lot of info out there. Then I use this tool I made that hooks onto my Stewmac Dremel base and I can go right to my markings that I made with the circle guide! ![]() Sent from my iPhone using Tapatalk |
| Author: | sdsollod [ Sat Aug 31, 2019 9:31 am ] |
Nice job Noah! After you use the Dremel to route the channels for the rosette, do you use a chisel to achieve the corners? |
| Author: | NJRiversguitars [ Sat Aug 31, 2019 9:37 am ] |
sdsollod wrote: Nice job Noah! After you use the Dremel to route the channels for the rosette, do you use a chisel to achieve the corners? Yes I use my Veritas Mini chisel set and clean the corners up to make them nice and sharp! When routing the segmented rosette I have learned to take very small passes so you have a nice clean channel to work with! Sent from my iPhone using Tapatalk |
| Author: | Bri [ Sat Aug 31, 2019 10:43 am ] |
The segmented rosette is awesome, so awesome that I expect to see a few attempts at it by the the folks here. I know that I am going to give it a try. Word is that imitation is the most sincere form of flattery. B |
| Author: | NJRiversguitars [ Sat Aug 31, 2019 10:48 am ] |
Bri wrote: The segmented rosette is awesome, so awesome that I expect to see a few attempts at it by the the folks here. I know that I am going to give it a try. Word is that imitation is the most sincere form of flattery. B Thank you so much Bri! Means a lot! I hope everyone pushes their comfort zone a little that’s when the artist in your self comes out! And you can really see what you are capable of. Sent from my iPhone using Tapatalk |
| Author: | sdsollod [ Sat Aug 31, 2019 4:23 pm ] |
BTW - Your Florentine cutaway looks a little different. You chose not to bind the point. It's not as pointy as usual and actually looks like a tiny rounded treatment. How did you execute that? And do you have some closeups to get a better look at it? |
| Author: | NJRiversguitars [ Sun Sep 01, 2019 12:10 pm ] |
sdsollod wrote: BTW - Your Florentine cutaway looks a little different. You chose not to bind the point. It's not as pointy as usual and actually looks like a tiny rounded treatment. How did you execute that? And do you have some closeups to get a better look at it? What I do is I make a typical sharp point cutaway and then round the edge exposing the inner cutaway block! ![]() Sent from my iPhone using Tapatalk |
