When I do a wipe on finish http://luthiersforum.com/forum/viewtopic.php?f=10101&t=52393 |
Author: | SnowManSnow [ Fri Sep 20, 2019 9:39 pm ] |
Post subject: | When I do a wipe on finish |
I’m testing some royal lac ... I remember having this issue before so I know it’s something I’m doing / not doing When I do a sip on finish the sheen is always streaky... almost like part of the finish is dry and some isn’t... it goes along w my strokes so it isn’t the wood... how do I keep it from looking streaky and look more uniform? Sent from my iPhone using Tapatalk |
Author: | Bri [ Fri Sep 20, 2019 10:12 pm ] |
Post subject: | Re: When I do a wipe on finish |
To paraphrase Willy, Well, theres the rub. (pun intended) Though no experience with royal lac, I do have experience with various wipe on finishes. I don’t worry too much about the streakiness until the final coat or two. I believe the issue you have is a bit too dry on the final coat. Thinning the last coat may help to flow out a bit better, but there is a fine line between too wet and too dry. I think that this is something that comes with experience. def. experience: the knowledge gained from a $#itload of mistakes B |
Author: | rlrhett [ Sat Sep 21, 2019 4:53 am ] |
I don’t think of shellac as a “wipe on” finish like TruOil or Minwax Wipe On Poly. To get a high quality finish I use a traditional French Polish technique. That said, as I build with Royal Lac I slowly begin incorporating walnut oil. A tiny amount. As in I dip the end of a finger in it and swipe across the muñeca. Do you use oil when wiping on shellac? That might help with streaking and surface tearing. Sent from my iPhone using Tapatalk Pro |
Author: | meddlingfool [ Sat Sep 21, 2019 3:26 pm ] |
I don't think RL is meant to be wooed on. There's a tut on their site on how to pad it on. I followed it and got very poor results. YMMV... |
Author: | SteveSmith [ Sat Sep 21, 2019 4:52 pm ] |
I french polish with Royal Lac and get good results. It does take practice. I use 4 or 5 drops of RL with 3 or 4 drops of alcohol when I load the muneca (however you spell that). I also use just a tiny bit of walnut oil but not every time. Attachment: IMG_20190613_103202820.jpg
