| Klingspor Pre-Cut Drum Sander Rolls... http://luthiersforum.com/forum/viewtopic.php?f=10101&t=52903 |
| Author: | meddlingfool [ Thu Feb 06, 2020 10:58 am ] |
| Post subject: | Klingspor Pre-Cut Drum Sander Rolls... |
I've heard here before that klingspor makes pre-cut sanding belts for drum sanders. I've been searching but can only find bulk rolls, not precut lengths. I'm specifically looking for rolls for a Delta 18-36...any tips? |
| Author: | Jim Watts [ Thu Feb 06, 2020 11:12 am ] |
| Post subject: | Re: Klingspor Pre-Cut Drum Sander Rolls... |
Ed, I don't know about Klingspor precut strips, but I've been using these https://woodworker.com/80-grit-readywra ... 32-587.asp The Zirconia seems to last really well, much better than the aluminum Oxide in my experience. |
| Author: | Bri [ Thu Feb 06, 2020 11:18 am ] |
https://www.woodworkingshop.com/categor ... ELTA+18-36 Try this, the blue zirconia definitely works better, but doesn’t seem to be available in precut. B |
| Author: | Tai Fu [ Thu Feb 06, 2020 11:23 am ] |
On that subject, do they make Zirconia sandpapers to fit Robo Sander drums? The paper doesn't last long and I have to switch them every 2 hour of use because they get loaded up especially if I sand an oily wood like EIRW. |
| Author: | Jim Watts [ Thu Feb 06, 2020 11:41 am ] |
The link I posted above is precut. They have it for many different sanders. |
| Author: | bobgramann [ Thu Feb 06, 2020 6:49 pm ] |
I’ve been buying precut rolls for the Delta 18-36 drum sander for some time. I just got a reorder last year. I had to poke around on the site a bit to find them. The Kingspor website did not go right to them. Searching for Delta 18 36 gets me this: https://www.woodworkingshop.com/product/dt31818/ They also have the feeder belt. |
| Author: | meddlingfool [ Thu Feb 06, 2020 8:33 pm ] |
Much thanks all! |
| Author: | bluescreek [ Fri Feb 07, 2020 7:31 am ] |
https://www.amazon.com/SuperMax-Pre-Cut ... B007OWX0RC |
| Author: | jshelton [ Fri Feb 07, 2020 4:23 pm ] |
meddlingfool wrote: I've heard here before that klingspor makes pre-cut sanding belts for drum sanders. I've been searching but can only find bulk rolls, not precut lengths. I'm specifically looking for rolls for a Delta 18-36...any tips? I don't understand why you would buy pre-cut belts when you can buy rolls so much cheaper. All you need is a used pre-cut one for a template and a few minutes time. I buy 3" X 50 yard rolls at https://www.supergrit.com/products/prod ... eeve-cloth for around $50. |
| Author: | doncaparker [ Fri Feb 07, 2020 4:45 pm ] |
The bulk rolls I buy have different colored stripes on the back of the abrasive that let me know where to cut for my specific sander. It's very handy. |
| Author: | Mike OMelia [ Fri Feb 07, 2020 5:02 pm ] |
doncaparker wrote: The bulk rolls I buy have different colored stripes on the back of the abrasive that let me know where to cut for my specific sander. It's very handy. Exactly. I used to buy the unmarked rolls from Klingspor. Real pain (u had to keep a template). Then they came out with the marked rolls. Just find the color line that corresponds to ur sander, cut, and go. Complete swap takes 5 minutes. Way cheaper than precut |
| Author: | Bri [ Fri Feb 07, 2020 5:11 pm ] |
For me the premarked are the only way to go. I don’t believe these are available for all applications though. B |
| Author: | Paul Micheletti [ Fri Feb 07, 2020 6:24 pm ] |
I bought the pre cut rolls from Klingspor. They came in a Jet box. So buying pre cut from them is the same product you get anywhere else. |
| Author: | meddlingfool [ Fri Feb 07, 2020 7:19 pm ] |
Currently I buy from Fintech, 2"x 50 yards for just under 20$. However, I'm playing broken telephone with the templates, the copy of the copy of the copy is getting hinky so I thought a fresh example would be useful to me. |
| Author: | Mike OMelia [ Sat Feb 08, 2020 10:17 pm ] |
Seriously, klingspor premarked rolls the way to go. See their info to see if ur sander is covered. |
| Author: | meddlingfool [ Sat Feb 08, 2020 10:29 pm ] |
It’s a delta 18-36 so hopefully... |
| Author: | Mike OMelia [ Sat Feb 15, 2020 3:04 pm ] |
Delta is covered in their cutlines |
