Plug Cutter
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=52920
Author:  Mike OMelia [ Sun Feb 09, 2020 3:17 pm ]
Post subject:  Plug Cutter
I got a 7mm fretboard dot slightly off center. Need a 7mm plug cutter, but so far only found 6mm, 8mm on Lee Valley, Veritas, etc. They taper 1.5 deg on a side. To grow to 7mm, I’d have to bore almost 7/8”. Can these cutters go that deep? I’d make a sacrificial board taped with African Blackwood.
Or buy the 8mm and spin sand down?
Author:  Clay S. [ Sun Feb 09, 2020 4:02 pm ]
Post subject:  Re: Plug Cutter
You can buy a fuller countersink that will have a 9/32nds diameter hole and chuck the drill bit in backwards so it will act as a plug cutter and make a 7mm plug.
https://wlfuller.com/html/high_speed_steel_sets.html
https://www.google.com/search?safe=acti ... RGo4d6BJnA
Author:  rbuddy [ Sun Feb 09, 2020 4:05 pm ]
What about cutting out an oversize dot from a fingerboard cutoff or matching wood. Gluing it to the end of a wood dowel. Spin it in a drill against sandpaper till it fits. Saw it off the end of the dowel and should be good to go.
Author:  Ken Lewis [ Sun Feb 09, 2020 4:14 pm ]
Router and template bushing?
Author:  SteveSmith [ Sun Feb 09, 2020 6:21 pm ]
Mike, I'm assuming it's a fairly shallow hole, and since it's only a one-time fix, my approach would be to go with an 8mm or 5/16" (7.9mm) plug and work it down by hand just like you would an inlay.
Author:  Clay S. [ Sun Feb 09, 2020 7:35 pm ]
If you have an 8mm plug cutter you could make an 8mm hole.
Author:  SnowManSnow [ Sun Feb 09, 2020 9:09 pm ]
Last time I did that I had to purchase bigger dots. Then drill the larger hole to cover the smaller one:/
Author:  Mike OMelia [ Sun Feb 09, 2020 9:31 pm ]
Ok. I’ll get the 8mm cutter and sand to fit. Makes sense. Thanks for not making feel like a bozo for doing this screwup lol!
Author:  SteveSmith [ Mon Feb 10, 2020 7:19 am ]
Hey Mike, it happens. Last time I screwed up a fret marker I put it on the wrong fret. Had to route out the whole area between the frets and put in new wood, fortunately it was an invisible repair.
Author:  Ruby50 [ Tue Feb 11, 2020 7:49 am ]
If it's just one, how about just using a chisel yo eat away the shape, get it close, and tap it into the hole
Ed
Author:  Mike OMelia [ Tue Feb 11, 2020 6:36 pm ]
Ed
Not sure what u mean. But my semi-ocd side won’t allow that. Bought an 8mm plug cutter. Gonna pull the dot. Sand the ebony down to 7, redrill and seat a new dot. Maybe I should switch to 8mm dots? Yeah. That’s next.
Author:  Bri [ Tue Feb 11, 2020 7:36 pm ]
Try this;
https://www.finewoodworking.com/2019/06 ... n-any-wood
Somewhere I bought a drill bit that matches the taper of a pencil sharpener.
B
Author:  Barry Daniels [ Wed Feb 12, 2020 9:24 am ]
B
Yeah, I had seen that bit before and then went looking online for it a few weeks ago for a project. I could not find it at any of the normal woodworking outlets. It may be out of production. If anyone knows where it is sold, please let me know.
Author:  bionta [ Wed Feb 12, 2020 9:36 am ]
Barry Daniels wrote:
B
Maybe this?
https://www.highlandwoodworking.com/tap ... l-bit.aspx
Author:  Barry Daniels [ Wed Feb 12, 2020 10:10 am ]
Hi Robert. That is not the one. The reamer had the same taper as a pencil sharpener. Thanks anyways.
I think it was carried by Lee Valley, but they don't have it anymore. I will send them an email to see what they know.
Author:  Barry Daniels [ Wed Feb 12, 2020 10:21 am ]
I found it at Veritas but it is no longer available.
http://www.veritastools.com/Products/Page.aspx?p=152
Author:  Mike OMelia [ Wed Feb 12, 2020 4:53 pm ]
That is an interesting idea. But it wouldn’t work. Don’t want end grain, and would need ebony (African Blackwood ) dowels.
Author:  Bri [ Wed Feb 12, 2020 6:19 pm ]
Actually, this would work fine.
Get a piece of 3/8” dowel, glue a piece of your finger board scrap to the end, sand to the diameter of the dowel and sharpen. You might try stacking the scrap pieces to get a bit more thickness to play with. No end grain.
You do need a good quality pencil sharpener to get a clean cut.
B
Author:  Mike OMelia [ Thu Feb 13, 2020 6:46 pm ]
Ok, I see ur point. I might try this. 3/8” is 2mm big, would seem straightforward to do
Author:  Mike OMelia [ Sat Feb 15, 2020 5:02 pm ]
So, I bought the 8mm plug cutter from Lee Valley. I cut 2 plugs from some scrap ABW about 3/16". Plugs are tapered, so I used CA to glue fat ends together, then chucked in one of my drills, then used a scraper with sandpaper glued to it (a favorite tool!) and a file to get it to right diameter. Glued and clamped in hole (after checking grain direction). Sanded down, redrilled, set a new marker. You cannot tell I did this. THanks!!
Author:  SteveSmith [ Sat Feb 15, 2020 5:49 pm ]
[:Y:]
