Making of Nemo1 http://luthiersforum.com/forum/viewtopic.php?f=10101&t=53242 |
Author: | bcombs510 [ Thu May 21, 2020 4:40 pm ] |
Post subject: | Making of Nemo1 |
Hello, I posted this in the ukulele forum where I’ve been posting pics in a build thread, but I thought I would share here too because it could be useful for any small bodied instrument, not just ukulele. I press frets using a Jaws2 and a Nemo1. The Nemo1 was born out of this thread from our friend Dave Farmer. fixing Jaws 2 https://r.tapatalk.com/shareLink/topic? ... source=app He’s not around on the OLF as much anymore but there are a ton of gems in his previous posts. ![]() If the big guy is Jaws2 then this has to be Nemo1. SM should sell this and give me royalties. As I mentioned this idea came from a post where David Farmer replaced the knock off Bessey clamp on the Jaws2 with a real one. Making the press screw into something compatible with the SM clamping caul is pretty straight forward. What I’m doing here is making a second clamp from the smallest Bessey clamp. This let’s me fret the last few frets in a small sound hole like a uke. First I have to remove the pin in the handle. I filed the pin head flat so that I can drill it out easier on the drill press. I used some scraps to try to square it up. ![]() Pop the cap off with pliers. ![]() ![]() ![]() I used an 1/8” dowel to encourage the pin out with a hammer. ![]() ![]() Pull out the press screw with pliers. ![]() This is what we are trying to replicate. The pin is 6.25mm with a slot cut that is 4.5mm. The slot is where the plastic set screw goes on the SM caul. ![]() ![]() Drilled a hole in the waste board so I can sink the press screw down and cut the slot using the files edge. ![]() ![]() ![]() Cut off the tip that was originally there with a hacksaw and file it flat in the drill press. ![]() ![]() Looks good. ![]() ![]() I used steel pop rivets to put the handle back on. ![]() I also trim the nose off just a bit so that it can get closer to the neck block. This helps with getting to reach as many frets as possible. I learned about the stubby Jaws2 from Dave and Hesh in their fretting class. ![]() ![]() ![]() I use a cut down version of the SM clamping caul so it can go in and out of the smaller sound hole. ![]() It’s a little fiddly to get it all set up through the sound hole but once set up it works great! ![]() Hope that is useful. Brad Sent from my iPhone using Tapatalk Pro |
Author: | Clay S. [ Fri May 22, 2020 7:00 am ] |
Post subject: | Re: Making of Nemo1 |
Looks "factory" Great job! |
Author: | jfmckenna [ Fri May 22, 2020 9:25 am ] |
Indeed! Very nice. |
Author: | SteveSmith [ Fri May 22, 2020 9:58 am ] |
Nicely done Brad. |
Author: | Pmaj7 [ Fri May 22, 2020 12:58 pm ] |
I like it, WTG Brad! Pat |
Author: | Joe Beaver [ Sat May 23, 2020 1:06 am ] |
Looks like just what I need. Great work!!! |
