| 142" resaw blade http://luthiersforum.com/forum/viewtopic.php?f=10101&t=54073 |
| Author: | oval soundhole [ Wed Mar 31, 2021 11:30 am ] |
| Post subject: | 142" resaw blade |
Hey everyone, I accidentally bought a 142" 3/4" resaw blade from highland woodworking only to realize it was the wrong size for my saw while attempting to install it (my saw requires 143"). I don't think I can return it now that I've discarded the packaging so if anyone would have any use for this please let me know! Only asking for shipping costs to you! |
| Author: | WudWerkr [ Wed Mar 31, 2021 11:51 am ] |
| Post subject: | Re: 142" resaw blade |
oval soundhole wrote: Hey everyone, I accidentally bought a 142" 3/4" resaw blade from highland woodworking only to realize it was the wrong size for my saw while attempting to install it (my saw requires 143"). I don't think I can return it now that I've discarded the packaging so if anyone would have any use for this please let me know! Only asking for shipping costs to you! That blade should work. |
| Author: | oval soundhole [ Wed Mar 31, 2021 11:58 am ] |
it should fit according to the manufacturer but it very much does not https://www.grizzly.com/products/grizzl ... vAQAvD_BwE |
| Author: | WudWerkr [ Wed Mar 31, 2021 12:07 pm ] |
oval soundhole wrote: it should fit according to the manufacturer but it very much does not https://www.grizzly.com/products/grizzl ... vAQAvD_BwE Are u getting the full drop on the top wheel when u loosen it , mine (diff saw) sticks some times and i have to tap it with rubber hammer to get it to go down all the way .. Just a thunk ? |
| Author: | oval soundhole [ Wed Mar 31, 2021 12:13 pm ] |
WudWerkr wrote: oval soundhole wrote: it should fit according to the manufacturer but it very much does not https://www.grizzly.com/products/grizzl ... vAQAvD_BwE Are u getting the full drop on the top wheel when u loosen it , mine (diff saw) sticks some times and i have to tap it with rubber hammer to get it to go down all the way .. Just a thunk ? Not stuck, unfortunately |
| Author: | Tim Mullin [ Wed Mar 31, 2021 1:15 pm ] |
I own the same Taiwanese-made saw, sold under the Australian Carbatec brand. You should be able to shorten the blade length requirement by turning the tension adjustment wheel. If that doesn’t give you enough, try measuring the blade to confirm the length they claim is incorrect. Sent from my iPad using Tapatalk |
| Author: | oval soundhole [ Wed Mar 31, 2021 1:53 pm ] |
| Post subject: | Re: 142 |
Tim Mullin wrote: I own the same Taiwanese-made saw, sold under the Australian Carbatec brand. You should be able to shorten the blade length requirement by turning the tension adjustment wheel. If that doesn’t give you enough, try measuring the blade to confirm the length they claim is incorrect. Sent from my iPad using Tapatalk I've just measured the blade and it is in fact 142". The tension wheel is as loose as it will go (with the quick tension lever set to loose) and it will not fit. Strange |
| Author: | Tim Mullin [ Wed Mar 31, 2021 2:11 pm ] |
So yours is not 142.75” but rather 142.0” . The saw is designed for 143”. I think you’ll have to eat it and reorder the correct length. Sent from my iPad using Tapatalk |
| Author: | oval soundhole [ Wed Mar 31, 2021 2:37 pm ] |
Tim Mullin wrote: So yours is not 142.75” but rather 142.0” . The saw is designed for 143”. I think you’ll have to eat it and reorder the correct length. Sent from my iPad using Tapatalk I did, that's why I'm offering this blade to anyone who could get some use out of it ![]() also the 3/4" was in reference to the width of the blade |
| Author: | Alaska Splty Woods [ Tue Apr 20, 2021 2:39 pm ] |
If you don't find a new home for the saw, You should be able to load that saw onto your wheels. Maybe by not the detention wheel as you have most likely tried, but you can use your tracking adjustment and tilt the top wheel out and down, like your adjusting the tracking out and that should give you the little bit you need to get the saw on the wheels. We have done this when loading 22' 6" saws made for the 42" New London Machine on to our 42" Industrial saw machines that use a 22' 8" saw. |
| Author: | surveyor [ Tue Apr 20, 2021 7:05 pm ] |
Hi Brian, If you can't use it I can, if the shipping 's not too outrageous. I'll just cut it, repair it and use it on my 20" saw. Send me a pm |
