| I think they could be on to something - http://luthiersforum.com/forum/viewtopic.php?f=10101&t=55049 |
| Author: | Michaeldc [ Mon Jun 06, 2022 8:28 pm ] |
| Post subject: | I think they could be on to something - |
3 drywall screws and a pair of 8mm bolts. Ought to hold! I wonder if the bolts go through that back as well. You know, to help with excessive bridge rotation due to extra light bracing.
| Author: | Chris Pile [ Mon Jun 06, 2022 9:01 pm ] |
| Post subject: | Re: I think they could be on to something - |
YE GODS. |
| Author: | doncaparker [ Mon Jun 06, 2022 9:28 pm ] |
That guitar is really screwed. |
| Author: | Hesh [ Mon Jun 06, 2022 9:37 pm ] |
Not enough break angle, needs string ramps and a neck reset. |
| Author: | Michaeldc [ Mon Jun 06, 2022 10:12 pm ] |
Hesh wrote: Not enough break angle, needs string ramps and a neck reset. Yup! |
| Author: | Terence Kennedy [ Mon Jun 06, 2022 10:44 pm ] |
Looks OK but I like to use a washer on mine. |
| Author: | joshnothing [ Mon Jun 06, 2022 10:46 pm ] |
I would have used M10 bolts - in case the player wants to go up a string gauge. |
| Author: | bcombs510 [ Tue Jun 07, 2022 8:53 am ] |
One of the few times where you finish a job, give it a few tugs and say “that’s not going anywhere” and you actually mean it! Sent from my iPhone using Tapatalk Pro |
| Author: | SteveSmith [ Tue Jun 07, 2022 10:13 am ] |
Make sure to use fender washers on the bottom. |
| Author: | jfmckenna [ Tue Jun 07, 2022 10:14 am ] |
Well in all fairness it is a 12-string! |
| Author: | WudWerkr [ Tue Jun 07, 2022 11:12 am ] |
I wish we could say this this type of stuff is unusual !
| Author: | Pat Foster [ Tue Jun 07, 2022 11:18 am ] |
Would have gotten better tone with brass bolts.
| Author: | doncaparker [ Tue Jun 07, 2022 11:34 am ] |
It's not every day you get to use a torque wrench to repair a guitar. |
| Author: | WudWerkr [ Tue Jun 07, 2022 12:50 pm ] |
doncaparker wrote: It's not every day you get to use a torque wrench to repair a guitar. Inch Lbs Or Ft Lbs
| Author: | joshnothing [ Tue Jun 07, 2022 5:15 pm ] |
The only issue is that sometimes these can seize up and even a cheater bar doesn’t always do the trick. In these cases I find heating them to cherry with a propane torch helps. As a bonus this will also convert your soundboard to torrefied and bring out the crisp highs. |
