| sander R/O http://luthiersforum.com/forum/viewtopic.php?f=10101&t=55439 |
| Author: | mikemcnerney [ Fri Jan 06, 2023 5:54 pm ] |
| Post subject: | sander R/O |
I am thinking about getting a 3" R/O sander (and maybe for buffing too) (and what size orbit is acceptable) so it's a bit easier to get in to the waist area. I don't have a large compressor so the palm style sanders, which would be my first choice, are probably not going to work for me unless someone has experience which this type using a smaller compressor.. As far as electric goes there are some cheaper ones by companies I've never heard of that I might consider. I'd like to hear from anyone that uses one or has another method for sanding & polishing the waist area |
| Author: | Mike OMelia [ Fri Jan 06, 2023 10:05 pm ] |
| Post subject: | Re: sander R/O |
I have been down this rabbit hole so much. Mirka has what you need in the old style sander. 3", ROS, small stroke. I almost went that way until I found a solution with Festool (did not want air tools). For me it was 3mm stroke, 3" and 5". Festool has that. But I found very similar solutions with Mirka. Airflow is the key thing. With Mirka, so much to look at. Self generating vacuum, non-vacuum. Ugh. But there are kits to convert. Here is the one I think you might like: https://buymirka.com/collections/mr-san ... ro-mr-3sgv 2.5mm good for finish work, 5mm good for aggressive work. |
| Author: | Colin North [ Sat Jan 07, 2023 7:06 am ] |
Just a small question, for buffing a finish I was under the impression a larger orbit was the way to go. I've been using a 12mm orbit DA polisher, like an Adams polisher. |
| Author: | SteveSmith [ Sat Jan 07, 2023 8:49 am ] |
I’ve got the Festool RO90. It’s a 3 1/2”. It works for me and I found I use it more than I expected. Too bad Festool tools are so so expensive. |
| Author: | Hesh [ Sat Jan 07, 2023 9:00 am ] |
My Festool cordless drill and 5" ROS and big-arse dust "extractor" are all 17 years old now and they have all performed beautifully and in a commercial environment too. Dave prefers less expensive drills and he's gone through three of them to my single Festool making mine less expensive. Good stuff |
| Author: | Mike OMelia [ Sat Jan 07, 2023 12:31 pm ] |
Colin North wrote: Just a small question, for buffing a finish I was under the impression a larger orbit was the way to go. I've been using a 12mm orbit DA polisher, like an Adams polisher. In the sanding world, smaller orbit equals less aggressive. I have the Adams polisher too. And if you are using the glaze like me, you know that it has almost no buffing grit. But, I cannot exactly answer your question. Maybe someone who understands car buffing can. |
| Author: | Mike OMelia [ Sat Jan 07, 2023 12:36 pm ] |
SteveSmith wrote: I’ve got the Festool RO90. It’s a 3 1/2”. It works for me and I found I use it more than I expected. Too bad Festool tools are so so expensive. That is the one I am getting (working sides of guitars). 125 ETS for the rest. Both have 3mm orbit. The RO90 worries me with that rotex setting. In Rotex mode, it becomes a beast. Gonna tape mine lol! |
| Author: | SteveSmith [ Sat Jan 07, 2023 2:40 pm ] |
Was just using it in that aggressive Mode. It is a beast but the selector is well marked and it doesn’t move easily. Steve |
| Author: | mikemcnerney [ Mon Jan 09, 2023 7:38 am ] |
I'm much closer to the end of my career and can't see spending the money for festool or mirka as much as I would like to. I will probably try the cheapo zota or manusage maybe a metabo at 280. do you need interface pads in the waist area for fine sanding & polishing. |
| Author: | windsurfer [ Mon Jan 09, 2023 11:33 am ] |
I have the 90mm metabo. Nice sander with excellent dust collection when connected to a vacuum. Only down side is the grip is on the large side. I use a soft pad when sanding anything that is not flat. |
