Arm bevel "Photo Essay"
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=55448
Author:  Colin North [ Thu Jan 12, 2023 3:05 am ]
Post subject:  Arm bevel "Photo Essay"
This caught my eye in my FB feed today, 4 part downloadable instructions for making an arm bevel from the The Phoenix Guitar Company.
May be of interest to some folks.
I've downloaded them but haven't read it yet, and have never made an arm bevel.
https://www.phoenixguitarco.com/services-8?fbclid=IwAR3lVRQymyKOkLbg7dbgj8HjAQ_68q82x-T9s7qyN9Qjn5vehd-KxwfW4qY
Opinions?
Author:  phavriluk [ Thu Jan 12, 2023 11:14 am ]
Post subject:  Re: Arm bevel "Photo Essay"
I did one arm bevel just because I wanted to do at least one. It added 50 percent to the fabrication work on the body. Looks nice, feels nice, one-and-done.
Author:  Darrel Friesen [ Thu Jan 12, 2023 12:48 pm ]
I did one only as well using Tony Karol's tutorial. On his, the binding and purfling are only on the top of the guitar and not on the lower part of the bevel as shown in the link. I believe the original Laskin style has binding and purfling on both the top and bottom of the bevel. I found Tony's relatively simple to do with a plexi router template and using the same wood for the bevel as used for the side wood (in my case mahogany) and so did not do any veneer work. In hindsight, I should have made it a little longer. It was a good learning experience and I would do a couple of things differently. Sorry for the picture quality. Phone cameras weren't so good back when I built this one.
Author:  SteveSmith [ Thu Jan 12, 2023 2:33 pm ]
I've also done one using Kent Everett's method. His method is pretty straight forward and it worked out well. It does add a lot of time to the box construction time so I'm not sure I'll do another one. It's on my personal guitar and I do like it.
Author:  DennisK [ Thu Jan 12, 2023 4:04 pm ]
It always amazes me how differently we each approach the same task :) I've done two so far, one without side purfling and one with. I construct the box as normal aside from using extra large dentellones in the bevel area. It's only after cutting the binding/purfling channels that I start removing material for the bevel.
http://www.luthiersforum.com/forum/viewtopic.php?f=10145&t=47798&start=75
For the second one, I cut the main binding/purfling channels, carved the bevel, glued the veneer, and then continued the channels into the bevel to create a sort of split binding with side purfling. For this style it actually would be helpful to make the support block as a single large piece, because then you could just carve through to it and leave it exposed in place of the veneer (assuming your sides are normal thickness, not like in the Phoenix Guitar essay). But without a bandsaw or edge sander or outside mold, I think the dentellones and veneer are easier.
Author:  Darrel Friesen [ Thu Jan 12, 2023 9:57 pm ]
Agreed Dennis. Many ways to do it. I'm re-inspired now and will have to do another one soon. Maybe a belly bevel too. :)
Author:  Mike OMelia [ Fri Jan 13, 2023 6:42 am ]
I kind of incorporated this into my baseline offereing. I do the same thing Steve does above, in fact, I thought I was looking at one of my own projects for a second. Steve, they sell aluminum push pins. Amazon. Much more durable. I have done so mnay of these that it is second nature now. First time I did it, scared the crap out of me.
Author:  Colin North [ Fri Jan 13, 2023 10:13 am ]
I can see why Taylor keeps it simple with it's Academy series with the time involved.
Author:  Dave Rickard [ Fri Jan 13, 2023 2:59 pm ]
I've done one and it came out okay, Guy that bought it likes it. Not sure I'll do another.
Author:  Mark Mc [ Fri Jan 13, 2023 6:34 pm ]
Another method, somewhat simpler, is the Mike Doolin bent top arm bevel. I followed his method, demonstrated here:
http://www.doolinguitars.com/articles/armbevel/
My result, slightly less elegant than Mr Doolin's, looked like this. It is very comfortable to play for a D-sized body.
Doolin does some fancy cutting of extra width binding strips to make the binding fit the side contour. I didn't - I found a standard straight binding strip could be coaxed to fit.
Author:  J De Rocher [ Fri Jan 13, 2023 8:32 pm ]
Is the guitar you built also fan-braced like the one shown on Doolin's web page, or is it x-braced?
Author:  Mark Mc [ Fri Jan 13, 2023 10:57 pm ]
Neither Jay. I am Australian, so of course it is falcate bracing.
Author:  J De Rocher [ Fri Jan 13, 2023 11:33 pm ]
Ha ha, of course it is!
