finial buffing and polish http://luthiersforum.com/forum/viewtopic.php?f=10101&t=56187 |
Author: | bluescreek [ Sun Jan 07, 2024 8:17 am ] |
Post subject: | finial buffing and polish |
when you get into finish work there is so much you don't know. A Prep if you short cut prep you create a lot of work and you won't get that perfect shine B What is the process Learn about sand papers and how to create the flat level surface I no longer use micro mesh my paper of choice is now all Assilex yes it isn't cheap but it lasts a long time and is a much higher end finish paper C buffing I use the arbor with a 1/3 hp motor and dual action hand buffer/polisher on the wheel I use Menzerna medium finish final finish on the hand buffer ( do all my final with these ) Menzerna heavy but Groits correcting cream buffing and polish compounds then I use maquires 204 and 3M finese it and hand glaze watch the link for the detailing to finese the perfect shine. https://www.youtube.com/@dallaspaintcorrectionautod8343 https://www.youtube.com/@dallaspaintcorrectionautod8343 |
Author: | dofthesea [ Sun Jan 07, 2024 12:02 pm ] |
Post subject: | Re: finial buffing and polish |
John Id like to purchase some Assilex paper which grits do you recommend? |
Author: | bcombs510 [ Sun Jan 07, 2024 12:47 pm ] |
John, I assume you are leveling any texture off the gun first before moving to assilex, is that correct? I level with 600 grit Mirka paper to 90% level and then 800 grit yellow film from Eagle to flat. Then switch to Assilex from there. The reason being that Assilex is not designed to level. This is from the techs at Eagle. It’s possible if the finish off the gun is impeccable going down to 600 is not needed. I am not there. Sent from my iPhone using Tapatalk Pro |
Author: | bluescreek [ Sun Jan 07, 2024 1:18 pm ] |
NO I only use the assilex it doesn't leave deep scratches like regular sandpaper I did get some 360 grit that doesn't come with the started kit. Don't hand sand , always use the sanding blocks and pads. and you can wet sand with it. when it gets blocked you can blow it clean with compressed air |
Author: | bcombs510 [ Sun Jan 07, 2024 1:48 pm ] |
Thanks, John. The devil is always in the details. ![]() Would you mind to post your exact steps through the grits? The reason I ask is that someone will buy the starter pack you linked to in the other thread and think they will get the same results. The starter set starts at 600. Trying to go from off the gun to buff using just that starter kit would be tough sledding. The techs at Eagle advised me to start with 400 or 600 grit paper, then switch to 800 grit yellow film before going to Assilex. That being said, that’s for UV cured poly, which is tough stuff, so may not be needed with all finishes. I too love working with the Eagle products and just want to make sure any of the forum members following along have a good experience. Sent from my iPhone using Tapatalk Pro |
Author: | bluescreek [ Sun Jan 07, 2024 8:41 pm ] |
I start with 350 assilex then just go through the grits I use my wheel buffer and dual action hand held the key is to learn to read the surface. That takes experience watch the surface its hard to say how to do it, as you learn to read the surface you will know when to go to the next grit I can buff out a guitar in about 2 hr |
Author: | Brad Goodman [ Sun Jan 07, 2024 10:14 pm ] |
bluescreek wrote: I start with 350 assilex then just go through the grits I use my wheel buffer and dual action hand held the key is to learn to read the surface. That takes experience watch the surface its hard to say how to do it, as you learn to read the surface you will know when to go to the next grit I can buff out a guitar in about 2 hr John, Which Dual action buffer do you use? |
Author: | Hesh [ Mon Jan 08, 2024 12:12 am ] |
Excuse me please how do you pronounce Assilex with a straight face ![]() ![]() ![]() |
Author: | bluescreek [ Mon Jan 08, 2024 6:23 am ] |
https://www.amazon.com/SPTA-Polishing-D ... hdGY&psc=1 this is a good one it has both the 3 and 5 in pads Hesh I dont |
Author: | bcombs510 [ Mon Jan 08, 2024 7:32 am ] |
Hesh wrote: Excuse me please how do you pronounce Assilex with a straight face ![]() ![]() ![]() What’s worse is the full name is Super Assilex. ![]() I just say Eagle Abrasives and leave it at that. ![]() Sent from my iPhone using Tapatalk Pro |
Author: | Darrel Friesen [ Mon Jan 08, 2024 9:47 am ] |
Hesh wrote: Excuse me please how do you pronounce Assilex with a straight face ![]() ![]() ![]() Doesn't everyone have a pair of assilex chaps? ![]() |
Author: | doncaparker [ Mon Jan 08, 2024 10:39 am ] |
Darrel Friesen wrote: Hesh wrote: Excuse me please how do you pronounce Assilex with a straight face ![]() ![]() ![]() Doesn't everyone have a pair of assilex chaps? ![]() Absolutely. For when I play dodgeball! |
Author: | J De Rocher [ Mon Jan 08, 2024 9:20 pm ] |
Darrel Friesen wrote: Hesh wrote: Excuse me please how do you pronounce Assilex with a straight face ![]() ![]() ![]() Doesn't everyone have a pair of assilex chaps? ![]() Perfect for astronauts traveling to Uranus. |
