Moxon Vise Finished http://luthiersforum.com/forum/viewtopic.php?f=10101&t=56202 |
Author: | Kbore [ Wed Jan 10, 2024 11:58 am ] |
Post subject: | Moxon Vise Finished |
Finished the Moxon vise. Thanks for all the suggestions. I chose the Moxon style because its portable and can be moved from bench to bench, can hold long stock for sawing, and conserves valuable space in my small cramped shop. Vise has provision for clamping to bench edge. For the body clamping jaw inserts, I used .090 thk mahogany practice-sides, covered with thick leather, using one thickness of mahogany spacer and one thickness of leather to create the needed top and back radius. The body clamping jaws slip on and off, over the threaded press screw. I will add a wide, adjustable belt webbing “sling” to catch a body that inadvertently slips through the jaws. ~~~~~~~~~~~~ Hard Maple jaws, shellac finish 12” Jorgensen Pony Press Clamps w/ Acme Thread Slotted movable jaw to eliminate racking (can easily clamp tapered pieces) |
Author: | Hesh [ Wed Jan 10, 2024 12:06 pm ] |
Post subject: | Re: Moxon Vise Finished |
That's pretty nice great job Karl!! |
Author: | meddlingfool [ Wed Jan 10, 2024 12:09 pm ] |
Very handy! |
Author: | ballbanjos [ Wed Jan 10, 2024 5:10 pm ] |
Sweet! |
Author: | bcombs510 [ Wed Jan 10, 2024 7:07 pm ] |
Nice! Sent from my iPhone using Tapatalk Pro |
Author: | Clay S. [ Thu Jan 11, 2024 10:48 am ] |
The press screws look handier than the pipe clamps many designs use. Nice! How wide can the vise go? |
Author: | Bryan Bear [ Thu Jan 11, 2024 12:15 pm ] |
I mentioned this to Karl off line but I'll add it here incase anyone is interested. I made a two screw moxon style vise built into my bench (probably similar to Clay's pipe clamp version). I made padded jaws just like a troji has out of plywood. They bolt into the chops of my vice and basically turn my two screw vice into a mounted troji for holding bodies. Just putting the two padded jaws away when not in use takes up much less space than an actual troji for those with limited shop space. |
Author: | Kbore [ Thu Jan 11, 2024 1:46 pm ] |
Clay S. wrote: The press screws look handier than the pipe clamps many designs use. Nice! How wide can the vise go? Thanks @Clay S. 7 7/16" wide between hardwood jaws (inserts removed) 6 3/16 wide between edge of jaw inserts (inserts installed) 7 1/8 wide between center of jaw inserts (accommodates 15/16" of center-to-edge dome) I could increase all above widths by 1/2"- 5/8" in a pinch (no pun) ![]() Opening width: Hardwood jaw thickness: 1 1/4" thick Double washer thickness on back of moveable jaw: 1/4" thick (easily removable) |
Author: | Kbore [ Mon Aug 05, 2024 7:02 pm ] |
Eight months later, I finally cut a mortise with the box in the vise. I added a simple hammock / cradle under the body for insurance. It added stability as well, a very easy, inexpensive and worthwhile upgrade- just a 1” strap (I used 2 because I didn’t have one long enough. I’ve had to tool up, significantly, to make my own necks…. Pics in reverse order ![]() |
Author: | bcombs510 [ Mon Aug 05, 2024 7:14 pm ] |
Nice! The strap is a great idea! Sent from my iPhone using Tapatalk Pro |
Author: | Bryan Bear [ Tue Aug 06, 2024 9:56 am ] |
I like the strap underneath. That is a great idea! |
Author: | CarlD [ Tue Aug 06, 2024 12:26 pm ] |
I use a couple of bands cut from a tire inner tube for that. Works for me. |
Author: | Darrel Friesen [ Tue Aug 06, 2024 4:24 pm ] |
Looks good! I have a Veritas twin screw vise that I use with some 1 1/2 ethafoam padding but I like the flexible plywood idea and the strap is also a good idea. I have pieces of pool noodle for covering the screws in case I get klutzy. ![]() |
Author: | Kbore [ Tue Aug 06, 2024 6:35 pm ] |
I need pool noodle! I also need to cap the back side of the screws, they are extra long and an accident waiting to happen. |
