| Cutting soundhole http://luthiersforum.com/forum/viewtopic.php?f=10101&t=56232 |
| Author: | Duct Tape [ Fri Jan 19, 2024 4:34 pm ] |
| Post subject: | Cutting soundhole |
I’m curious how many rout out their soundhole after final thicknessing of the top, vs other techniques? I’ve read somewhere of someone routing it out befor final thicknessing (obviously only the back side) and the cut out falling out after a certain thickness vs depth of cut is reached. |
| Author: | meddlingfool [ Fri Jan 19, 2024 4:54 pm ] |
| Post subject: | Re: Cutting soundhole |
After thicknessing for me. I install my rosettes in a .070 channels. I use the same bit in the same router to cut the sound hole. First cut is still .070, then flip the top and route the rest of the way through from the back… |
| Author: | Alan Carruth [ Fri Jan 19, 2024 5:48 pm ] |
I inlay the rosette, thickness the top, glue on a 'doubler' around the hole, and then cut the hole through the doubler and the top at the same time. The doubler and the braces around the hole go out as far as the edges of the rosette to reinforce the top there. |
| Author: | J De Rocher [ Fri Jan 19, 2024 6:58 pm ] |
- Thickness the top - Install the rosette and soundhole binding - Level the rosette and soundhole binding - Rout out the soundhole |
| Author: | SteveSmith [ Fri Jan 19, 2024 7:15 pm ] |
After final thicknessing here too. |
| Author: | bcombs510 [ Fri Jan 19, 2024 11:49 pm ] |
Sometimes I do this thing where I inlay a solid ring as the sound hole binding. I do this before final thickness when the top is at ~.140. I make sure the ring is around .125 which will be thicker than the final top. Once the ring is inlaid I cut the sound hole which is a smaller diameter than the ring by .060 leaving a .030” sound hole binding. Sounds difficult but it’s just difficult to type. ![]() ![]() Otherwise, after final thickness. I learned the inlaid sound hole binding here. I can’t remember who shared it, maybe Terry Kennedy, cannot remember. Actually, here is where I saw it, from Jay and he attributed Rick Davis - viewtopic.php?f=10101&t=49844&start=25 Brad Sent from my iPhone using Tapatalk Pro |
| Author: | Duct Tape [ Mon Feb 19, 2024 12:33 pm ] |
meddlingfool wrote: After thicknessing for me. I install my rosettes in a .070 channels. I use the same bit in the same router to cut the sound hole. First cut is still .070, then flip the top and route the rest of the way through from the back… Where does that leave you top thickness? Obviously at least a little under .140” (3.5mm), maybe more. And perhaps this is a rough thickness snd your final is even less? Thanks |
| Author: | meddlingfool [ Mon Feb 19, 2024 12:37 pm ] |
always well under .140… |
