Truss rod length and installation
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=56838
Author:  Juergen [ Sat Oct 19, 2024 9:22 am ]
Post subject:  Truss rod length and installation
Recently I`ve seen a YouTube video fro a german luthier who build a comissioned steel string guitar. The truss rod nearly reached the soundhole and was not embedded in the neck block extension for nearly 5 cm. The guitar was a dread. Is the length of the truss rod determined for a correct action of the rod, or doesn`t it matter? Robbie O`Brian places his truss rods with the moving parts beginning at the neck-body-joint.
How do you install your truss rods?
Juergen
Author:  Hesh [ Sun Oct 20, 2024 3:44 am ]
Post subject:  Re: Truss rod length and installation
Hi Juergen I was like Robbie with the rod only effective from the 1st fret to the body joint. That's how they are all in my experience.
Author:  Bob Orr [ Sun Oct 20, 2024 9:00 am ]
I stop mine at the head block too.
Author:  Michaeldc [ Sun Oct 20, 2024 10:18 am ]
I'm assuming this is for headstock access and not sound hole access?
Author:  Kbore [ Sun Oct 20, 2024 1:47 pm ]
I stop my truss rods at the tenon of the heel block, with access from the sound hole, and extending to between the first fret and nut.
THats how I built my first guitar, and subsequent ones.
Author:  SteveSmith [ Sun Oct 20, 2024 1:53 pm ]
Yep.
Author:  J De Rocher [ Sun Oct 20, 2024 3:14 pm ]
Yep.
Same here. The threaded block at the nut end of the rod rests on top of the tenon just past the neck/body joint.
