Spring steel slats
http://luthiersforum.com/forum/viewtopic.php?f=10102&t=11302
Author:  John How [ Fri Mar 16, 2007 11:41 am ]
What's the name of the industrial supply house that sells the string steel by the roll?
Also what thickness do you guys use for your benders?
TIA, John
Author:  John How [ Fri Mar 16, 2007 12:31 pm ]
Thanks Michael, I just found & ordered some from MSC.
Author:  Brad Way [ Fri Mar 16, 2007 3:45 pm ]
John,
   I purchased a few rolls from McMaster Carr. I purchased the .007 Blue Tempered Spring Steel. I recently purchased a roll of .015 Stainless for a new bender I am working on and it seems thick. Probably .010 would be good.
Author:  Kim [ Fri Mar 16, 2007 6:39 pm ]
I believe that .010 is indeed the gauge of choice for blued steel slats John.
Author:  John How [ Fri Mar 16, 2007 9:38 pm ]
The stuff I ordered is.012" thick so I think it'll be fine. MSC also has 6"x50" pieces so you don't have to buy 20 ft to get a couple of workable slats.
Author:  Brad Way [ Sat Mar 17, 2007 1:08 am ]
John,
   Are you making some mods to your bender?
Author:  Cocephus [ Sat Mar 17, 2007 7:40 am ]
I`m looking for some slats as well. How long/ many uses does one get before they get brittle, or will they?
Author:  tippie53 [ Sat Mar 17, 2007 3:07 pm ]
I have found that .015 is what you need. I carry them and they are in stock. Check out my online catalog.
john hall
Author:  John How [ Sat Mar 17, 2007 4:57 pm ]
[QUOTE=Brad Way] John,
   Are you making some mods to your bender?[/QUOTE]
No, just replacing the wornout slats
