Photoshop color problem/question http://luthiersforum.com/forum/viewtopic.php?f=10102&t=11502 |
Author: | James Orr [ Tue Apr 03, 2007 6:08 pm ] |
Post subject: | |
Hi guys I'm having color issues in photoshop. When I save for web, the image somehow changes color space and no longer matches the same hex color in html. For example: In photoshop I'll measure a color as #414141 In CSS I'll match the color: #414141 When I check the web, the two are noticably different: http:// languagepool.net/index_test.php When I slide my image in photoshop over the CSS rendered gray, they are the same, so the color is changing during the save for web process. The original gray in photoshop was 414141 (C: 68 M: 61 Y: 60 K: 46). The saved gray has become 323232 (C: 68 M: 61 Y: 60 K: 46). The CSS's gray is 414141 (C: 64 M: 57 Y: 56 K: 33). Any ideas??? |
Author: | Billy T [ Tue Apr 03, 2007 6:54 pm ] |
Post subject: | |
Are you saving as a .gif, .png or .jpg? .gif will truncate the color slightly but noticable! |
Author: | Pwoolson [ Tue Apr 03, 2007 10:50 pm ] |
Post subject: | |
Try converting to RGB before saving to web. I think you might be loosing your color because you are doing an RGB conversion and a JPG conversion at the same time. |
Author: | burbank [ Wed Apr 04, 2007 3:28 am ] |
Post subject: | |
You might look at using "web safe" colors. There's a small selection, but they survive intact with lower-bit color resolution. You might do ok if you're after greys. Another problem that arises is that browsers render colors differently if they're not web safe. I had the same problem, I think, with the dark blue on this page where the banner across the top overlaps the left column. The banner's dark blue is from Photoshop and the color in the column was from Dreamweaver. I had to just juggle them to get them to match, playing with each color to get it right. I couldn't get it to look right in Safari, Firefox and Internet Explorer. It would look OK in one, but not the others, so I went with IE since it's the most widely used (arrghhh). The numbers don't match, but the colors sorta do, unless you look at it on an LCD screen at a high angle. I'm probably the only one that notices. I couldn't find what I wanted in web safe colors. |
Author: | James Orr [ Wed Apr 04, 2007 4:16 am ] |
Post subject: | |
Guys, thanks for talking this through. It's really the strangest issue, but I believe I found the setting I'd switched. I've always used Save for Web because it changes the resolution to 72dpi for you. Just a saved step. I started having this color issue a few months ago, only, it didn't bug me until I was trying to match these grays last night. I believe the issue was that I somehow clicked the "Save with ICC Profile" option. Look at these two images. The bottom has the correct color and was saved w/o the ICC profile. http://www.languagepool.net/images/saveWICC.jpg http://www.languagepool.net/images/saveWOICC.jpg - correct color Very interesting. |
Author: | James Orr [ Wed Apr 04, 2007 4:18 am ] |
Post subject: | |
Being able to ask questions like this and talk them through really goes to show the breadth of knowledge in this forum. That's incredible in and of itself. |
