I may be a convert!! http://luthiersforum.com/forum/viewtopic.php?f=10102&t=11516 |
Page 1 of 2 |
Author: | old man [ Thu Apr 05, 2007 8:12 am ] |
Post subject: | |
Well, I broke down and bought a blanket from John at Blues Creek, and tried it out yesterday and today. I bent some VERY curly white oak (from BobC) to an OM shape (first time for anything other than a dread). On the first side I had a little bit of cracking in the high figure, but it will be OK. On the second side, I took off another .001 or so, spritzed it twice, made sure it was hot enough, and it bent very well. Still in the bender, but I didn't hear anything snap. ![]() Thanks a lot, John, I'll be back. ![]() Ron (an OLD and WISER man) |
Author: | burbank [ Thu Apr 05, 2007 8:34 am ] |
Post subject: | |
Better a convert than a prevert, I always say! Welcome to the fold, Ron! ![]() |
Author: | Rod True [ Thu Apr 05, 2007 8:52 am ] |
Post subject: | |
Agreed who heartedly. I broke two sets of maple and one set of Imbuia using my old bender and bulbs. The blanket rocks. Ron's only a bluegrass prevert, likes to fondle banjo's ![]() Bob C's the zoot pimp though. |
Author: | Sam Price [ Thu Apr 05, 2007 8:57 am ] |
Post subject: | |
hahhhahh, too funny guys.. So, how much DOES a blanket cost? Uh....only asking...because.... |
Author: | James W B [ Thu Apr 05, 2007 9:10 am ] |
Post subject: | |
I sleep with a blanket every night. James ![]() |
Author: | Rod True [ Thu Apr 05, 2007 10:20 am ] |
Post subject: | |
Sam, John Hall in the US sells them along with a 220V (I'm pretty sure he has them in 220V anyway) for about 165 including a control switch. Check out his site here. This pays for itself the very first time you wreck a nice set of sides (learn from my mistakes) and have to replace them. Of course using a blanket is not fool proof but it sure gives consistent heat to the wood unlike bulbs. |
Author: | Rod True [ Thu Apr 05, 2007 10:23 am ] |
Post subject: | |
Back off, get your own sandwich ![]() |
Author: | phil c-e [ Thu Apr 05, 2007 12:04 pm ] |
Post subject: | |
ron, i'm with you on the miracles of the blanket. not only did i get the blanket from john, i also got a lot of free advice. amazing service!! i did snap one set while learning, but a bit more free advice from john and i've now succesfully bent sapele and wenge. both beautiful woods that are known to cause some bending trouble. i'm sold on the blanket and john hall. by the way ron, even though 95% of the blanket bending pictures we see have the blanket between the slats, i went with john's advice and left the blanket as the last layer of the sandwich. worked like a charm as did his idea of bending the lower, then upper bout, and finally the waist. again, that's not how most of the advice out there goes, but it worked beautifully. phil |
Author: | stan thomison [ Thu Apr 05, 2007 12:14 pm ] |
Post subject: | |
ours is set same as Hesh with exception we use bakers parchment and not foil. Since most are archtop, use maple and almost never any discoloration or burn. |
Author: | stan thomison [ Thu Apr 05, 2007 12:16 pm ] |
Post subject: | |
darn no edit button, but add to last we only use the two cauls and the center caul for bends. |
Author: | Bobc [ Thu Apr 05, 2007 12:21 pm ] |
Post subject: | |
I also use John's method for bending but also use a .010 slat over the blanket. I don't think it makes any difference in bending but do it for 2 reasons. 1. It prevents the spring loaded cauls from abrading the blanket and eventually wearing thru to the wires 2.The cauls slide much easier over the steel slat. Of course I good be all wet too. ![]() |
Author: | old man [ Thu Apr 05, 2007 1:31 pm ] |
Post subject: | |
I just did slat-wood-blanket-slat. What's wrong with that, huh????? Pervert, eh? I'll show you perversion. Ron |
Author: | old man [ Thu Apr 05, 2007 1:34 pm ] |
Post subject: | |
Perversion at it's finest!! ![]() Ron |
Author: | JohnAbercrombie [ Thu Apr 05, 2007 2:13 pm ] |
Post subject: | |
BTW, not all the blankets out there are the same. I have one from LMII which is smooth and one which came originally from John Hall (I bought it second-hand), which has raised wires. Both work very well, but the Hall blanket definitely raises more concerns in me about abrasion and ability to slide under the cauls. I use a 'modified Doolin' method of bending- tension on the slats, waist last. John |
Author: | Sam Price [ Thu Apr 05, 2007 6:03 pm ] |
Post subject: | |
[QUOTE=Rod True] Sam, John Hall in the US sells them along with a 220V (I'm pretty sure he has them in 220V anyway) for about 165 including a control switch. Check out his site here. This pays for itself the very first time you wreck a nice set of sides (learn from my mistakes) and have to replace them. Of course using a blanket is not fool proof but it sure gives consistent heat to the wood unlike bulbs.[/QUOTE] Thanks for that. ![]() |
Author: | robertD [ Thu Apr 05, 2007 9:46 pm ] |
Post subject: | |
[QUOTE=Rod True] Ron's only a bluegrass prevert[/QUOTE] PREVERT? Is that like, the first step to becoming a pervert? ![]() Seriously though, Ron, congrats on the new blanket! Nothing like the FEEL of a new tool! ![]() Robert |
Author: | Dave Rickard [ Thu Apr 05, 2007 11:09 pm ] |
Post subject: | |
Ron (an OLD and WISER man)[/QUOTE] ![]() |
Author: | tippie53 [ Fri Apr 06, 2007 12:22 am ] |
Post subject: | |
I have to say this made my morning. After I cleaned all the coffee I spit onto the screen after reading I was a pervert and I had my wife read this , I am afraid you guys may know me too well. Thank you for all the kind words as we do try to treat each and evry customer as we want to be treated. Have a great Easter I think it may be from the lacquer john hall |
Author: | Dave Rickard [ Fri Apr 06, 2007 4:07 am ] |
Post subject: | |
[QUOTE=Dave Rickard] Ron (an OLD and WISER man)[/QUOTE] ![]() I read this again and it didn't come out like I was thinking. Ron is a wise man. You need to know his last name to understand what I was laughing at. Okay I'll shut up and go back to work. Sorry about that |
Author: | Lillian F-W [ Fri Apr 06, 2007 6:44 am ] |
Post subject: | |
[QUOTE=tippie53] I have to say this made my morning. After I cleaned all the coffee I spit onto the screen after reading I was a pervert .... [snipe] john hall [/QUOTE] John, you might have to trust me on this, but spiting it out on the screen is much better than inadvertently snorting it while laughing. You really don't want the details, but it did involve soda, Billy T and Hesh. Enough said I think. |
Author: | nickton [ Sun Apr 08, 2007 6:54 pm ] |
Post subject: | |
I know this doesn't have much to do with preversion or spite, but I couldn't help noticing when I checked out this thread: Is that James Joyce playing the banjo, or is it just me??? ![]() |
