Router question http://luthiersforum.com/forum/viewtopic.php?f=10102&t=11533 |
Author: | Lillian F-W [ Fri Apr 06, 2007 11:32 am ] |
Post subject: | |
I have a Porter Cable 690 that I want to use in a table set up. I was just wondering if it is worth getting a 1/2" collet? Any thoughts or insights? |
Author: | crazymanmichael [ Fri Apr 06, 2007 12:23 pm ] |
Post subject: | |
yes. they are usually available on ebay for $10-$12. a 1/2" shank bit is much more rigid and less prone to breakage and vibration. i use a 1/2" whenever possible. |
Author: | Hank Mauel [ Fri Apr 06, 2007 3:41 pm ] |
Post subject: | |
[QUOTE=crazymanmichael] yes. they are usually available on ebay for $10-$12. a 1/2" shank bit is much more rigid and less prone to breakage and vibration. i use a 1/2" whenever possible.[/QUOTE] What he said! Are you also considering a "router lift" unit? It makes setting heights of cuts REALLY easy and most will take the PC690 as a standard set up. I've got one on my router table and it is invaluable. |
Author: | Lillian F-W [ Fri Apr 06, 2007 4:39 pm ] |
Post subject: | |
Thanks guys. Much appreciated. |
Author: | Shawn [ Sat Apr 07, 2007 12:55 am ] |
Post subject: | |
The only time when it is better to not use a 1/2" collet in a router is when the bit diameter is less than 1/4". In that case it is better to stick with the 1/4" collet as the shaft of the bit is the same throughout. |
Author: | Lillian F-W [ Sat Apr 07, 2007 5:15 am ] |
Post subject: | |
Thanks Shawn. |
Author: | Mattia Valente [ Mon Apr 09, 2007 3:21 am ] |
Post subject: | |
What Shawn said. Ever since getting my 1/2" collet, I won't use 1/4" bits unless I really have to (ie, truss rod slots, CF slots). Especially for heavy work, it adds monstrous amounts of stability. I'm pondering getting a second router - either another 690 or an 890 - for my table; I use my 690 for so many tasks I don't feel like having it tied up in the table! |
