First Time Intonation Questions http://luthiersforum.com/forum/viewtopic.php?f=10102&t=11541 |
Author: | dmills [ Sat Apr 07, 2007 3:48 am ] |
Post subject: | |
I just finished my first guitar a few weeks ago. I set the string clearances to about 75% of where they need to be and set it aside for a few weeks for the guitar to settle in under tension. I am now ready to finish the setup and want to make sure I am going about it correctly.
Thanks for the help. |
Author: | dmills [ Sat Apr 07, 2007 6:05 am ] |
Post subject: | |
Thanks for the clarifications Hesh. One other question regarding the E string intonation method before the bone dust flies. I assume –
Author: | Joe Beaver [ Sat Apr 07, 2007 6:26 am ] |
Post subject: | |
Doug, I believe you have it. Great advice from Hess!! One note... Many recommend setting the break point in this fashion.. 1. check the fingerboard to make sure the frets are level 2. adjust the truss rod 3. set the nut and saddle to the height you like 4. tune the guitar with the strings you prefer 5. play it now and again for a day or so 6. tune it again 7. loosen one string at a time and put a small piece of .12 or so wire on top of the saddle. 8. now retune, getting it as dead on as you can 9. fret the 12th fret and pluck, Look at the tuner. Now play the 12th fret harmonic. Move the wire until the harmonic and 12th fret plucked note match. (You will notice this is the tricky part. This method has you setting the intonation against the 12 fretted and the 12th harmonic, not the open string.) 10. mark the center of your final location of the piece of wire and file to this mark |
Author: | crazymanmichael [ Sat Apr 07, 2007 7:43 am ] |
Post subject: | |
i am puzzled by hesh's reference to the flat harmonic. i consider that it is the fretted note, not the harmonic, that should be used to adjust intonation since compensation is introduced to counter the increased string tension, etc., created when the string is fretted. i agree that a wider saddle gives more lattitude in correcting intonation. with a 3/32 saddle you may well end up with the string break point being on the back edge of the saddle, depending upon bridge location accuracy, saddle slot compensation, etc. you are correct that action height and neck relief should ideally be set before doing the compensation exercise. |
Author: | SniderMike [ Sat Apr 07, 2007 7:55 am ] |
Post subject: | |
[QUOTE=crazymanmichael] i am puzzled by hesh's reference to the flat harmonic. i consider that it is the fretted note, not the harmonic, that should be used to adjust intonation since compensation is introduced to counter the increased string tension, etc., created when the string is fretted. [/QUOTE] I agree with you, Michael. Hesh, I don't think that will give you accurate intonation, as you're not lengthening the string using the harmonic as you would by fretting at the 12th fret. In fact, I believe the "12th fret" harmonic (which doesn't really "care" where your fret is) is always exactly an octave above the open string, no? What I'm saying is, I don't think it's possible for the harmonic to be sharp or flat from the open string. Someone correct me if I'm wrong. |
Author: | SniderMike [ Sat Apr 07, 2007 8:08 am ] |
Post subject: | |
Hesh, my apologies if I'm just misunderstanding your technique, by the way. |
Author: | SniderMike [ Sat Apr 07, 2007 9:38 am ] |
Post subject: | |
Gotcha Hesh. I did indeed misunderstand your technique. I should have known that you're smarter than that ![]() |
Author: | crazymanmichael [ Sat Apr 07, 2007 3:52 pm ] |
Post subject: | |
i am still puzzled at this description of procedure and am suprised that no one has noticed the flaw. or am i delusional? if the open string is in tune and that string fretted at the 12th is in tune, compensation is fine, and nothing further needs to be done to it. |
Author: | crazymanmichael [ Sat Apr 07, 2007 11:58 pm ] |
Post subject: | |
agreed. perhaps i just read the second and third paragraph of that post to be contradictory when that was not your intent. sorry if i misunderstood what you intended to say. |
