Spanish tourniquet in use - video link http://luthiersforum.com/forum/viewtopic.php?f=10102&t=11614 |
Author: | burbank [ Thu Apr 12, 2007 10:13 am ] |
Post subject: | |
Found this on youtube Spanish tourniquet I'd never seen one in use, thought I'd post. I love low-tech stuff that works, like the tape method. |
Author: | Pwoolson [ Thu Apr 12, 2007 10:55 am ] |
Post subject: | |
Pat, I use one for every plate joint. Backs, Tops, archtops. I'm like you in that I love simple stuff that gets teh job done well. I do mine slightly differently: I don't tie off each wedge as I think it works better as a whole with them all as one unit. |
Author: | Don A [ Thu Apr 12, 2007 12:04 pm ] |
Post subject: | |
Thanks Pat. I've never seen the actual process myself. With only 3 flat boards and 3 wedges, can't get much simpler or take up much space. As a grumpy old luthier use to say, KISS. ![]() |
Author: | Rod True [ Thu Apr 12, 2007 12:29 pm ] |
Post subject: | |
Pepe is a member over on the MIMF. I've never heard of pounding the wedges in like that. I like Paul just run the entire wrap (I have 4 wedge points) and than put the wedges in. I like this method the most of which I've tried, but that's my own personal taste. Lots of good ways to join the plates. |
Author: | Rod True [ Thu Apr 12, 2007 12:43 pm ] |
Post subject: | |
Wax paper or something on the wood pieces. I used two sided tape and left the paper on the one side. Heck even packing tape would do the trick. |
Author: | CarltonM [ Thu Apr 12, 2007 4:10 pm ] |
Post subject: | |
Thanks Pat. It's always easier to understand when somebody shows you how to do it. |
Author: | WaddyThomson [ Fri Apr 13, 2007 12:59 am ] |
Post subject: | |
That was a good link. That guy can really move. I don't think I could move that fast if my buns were on fire. It was like the top was pretty well stuck before any pressure was applied. |
Author: | crazymanmichael [ Fri Apr 13, 2007 2:13 am ] |
Post subject: | |
any time one uses wood around glue it behooves you to remember that wax is your friend. well waxed wood prevents glue from sticking and any traces are easily removed with naphta. but one caveat; always make sure the wax used is free of silicone. ost good paste waxes fill the bill are avialable from hardwares, woodworking stores, etc. |
Author: | burbank [ Fri Apr 13, 2007 4:14 pm ] |
Post subject: | |
[QUOTE=Pwoolson] Pat, I use one for every plate joint. Backs, Tops, archtops. I'm like you in that I love simple stuff that gets teh job done well. I do mine slightly differently: I don't tie off each wedge as I think it works better as a whole with them all as one unit. [/QUOTE] Paul, I'm with you there, letting the forces equalize among all the wedges. You're all most welcome. |
