OLF Tutorial Page http://luthiersforum.com/forum/viewtopic.php?f=10102&t=12643 |
Page 1 of 2 |
Author: | bob_connor [ Fri Jun 29, 2007 12:47 pm ] |
Post subject: | |
I've started compiling an OLF Tutorial page which can be found here. OLF Tutorial Page So now I need some assistance as the archives are so huge now it'd take me forever to search for every tutorial in there and I'd probably miss some anway. If you could post in this thread the URL (ie the thing at the top of your browser that starts with http://www. etc together with a description of any tutorial and the author I will add it to the page. Once we have it compiled it will be a trivial job for Lance or Brock to copy the code and integrate it into the new forum software. Cheers |
Author: | WaddyThomson [ Fri Jun 29, 2007 12:55 pm ] |
Post subject: | |
Don't forget Mike Blanchard's "Cutaway Neck Joint". http://www.blanchardguitars.com/cutaway/cutaway.html |
Author: | LanceK [ Fri Jun 29, 2007 12:55 pm ] |
Post subject: | |
Now THAT is sweet! Bob thanks for your help! ![]() |
Author: | WaddyThomson [ Fri Jun 29, 2007 1:16 pm ] |
Post subject: | |
Here is another. Hesh's "Tape Method - Joining plates" Good tutorial on using masking tape to join top or back plates. http://www.luthiersforum.com/forum/search.asp?KW=tape+method &SM=1&SI=TC&FM=2&OB=1#forumTop |
Author: | burbank [ Fri Jun 29, 2007 1:46 pm ] |
Post subject: | |
Very cool, Bob. Thanks! |
Author: | WaddyThomson [ Fri Jun 29, 2007 2:09 pm ] |
Post subject: | |
"Installing Back Strips" Another Tootman Tutorial (Hesh) http://www.luthiersforum.com/forum/forum_posts.asp?TID=11167 &KW=tutorial#forumTop |
Author: | WaddyThomson [ Fri Jun 29, 2007 2:17 pm ] |
Post subject: | |
"Paua Purfling (How we did it) by Bob Connor Nice pictures and explanation of installing paua and the other wood purfling on a guitar. http://www.luthiersforum.com/forum/forum_posts.asp?TID=10573 &KW=tutorial#forumTop |
Author: | Jebarri [ Fri Jun 29, 2007 2:20 pm ] |
Post subject: | |
I did a quick search through the archives and this is what I came up with. Armrest Tutorial: http://www.luthiersforum.com/forum/forum_posts.asp? TID=11968&KW=tutorial#forumTop Gap Filling Tutorial: http://www.luthiersforum.com/forum/forum_posts.asp? TID=11580&KW=tutorial#forumTop Bridge Patch Tutorial: http://www.luthiersforum.com/forum/forum_posts.asp? TID=11349&KW=tutorial#forumTop Classical Bridge Tutorial: http://www.luthiersforum.com/forum/forum_posts.asp? TID=11276&KW=tutorial#forumTop Turning Pins Tutorial: http://www.luthiersforum.com/forum/forum_posts.asp? TID=11262&KW=tutorial#forumTop Mounting an Acoustic Pickup Tutorial: http://www.luthiersforum.com/forum/forum_posts.asp? TID=11169&KW=tutorial#forumTop Side bending Tutorial: http://www.luthiersforum.com/forum/forum_posts.asp? TID=11104&KW=tutorial#forumTop Slotted Head Tutorial: http://www.luthiersforum.com/forum/forum_posts.asp? TID=11045&KW=tutorial#forumTop Bridge Removal Tutorial: http://www.luthiersforum.com/forum/forum_posts.asp? TID=11038&KW=tutorial#forumTop Bench Sander Miters Tutorial: http://www.luthiersforum.com/forum/forum_posts.asp? TID=11038&KW=tutorial#forumTop How to Make a Guitar Mold Tutorial: http://www.luthiersforum.com/forum/forum_posts.asp? TID=10884&KW=tutorial#forumTop V-Joint Tutorial: http://www.luthiersforum.com/forum/forum_posts.asp? TID=10011&KW=tutorial#forumTop |
Author: | WaddyThomson [ Fri Jun 29, 2007 2:24 pm ] |
Post subject: | |
Fret Press Arbor and Fretting (Pics) Hesh Tutorial http://www.luthiersforum.com/forum/forum_posts.asp?TID=10433 &KW=tutorial#forumTop Fretting with the Stew Mac Fret Press Arbor |
Author: | WaddyThomson [ Fri Jun 29, 2007 2:32 pm ] |
Post subject: | |
http://www.luthiersforum.com/forum/forum_posts.asp?TID=10344 &KW=%28pics%29#forumTop |
Author: | Dave Anderson [ Fri Jun 29, 2007 2:34 pm ] |
Post subject: | |
Thanks a lot Bob ! Here is one I did a while back, "First time mitres" http://www.luthiersforum.com/forum/forum_posts.asp?TID=9654& KW=DaveAndy#forumTop |
Author: | WaddyThomson [ Fri Jun 29, 2007 3:03 pm ] |
Post subject: | |
Here are some more not labeled as tutorials, but are. How I cut lapjoints (pics) - Bob Connor http://www.luthiersforum.com/forum/forum_posts.asp?TID=10833 &KW=%28pics%29#forumTop Correcting Neck Backbow (Pics) - Hesh http://www.luthiersforum.com/forum/forum_posts.asp?TID=9702& amp;KW=%28pics%29#forumTop Shimming Neck and Tail Blocks (Pics) - Hesh http://www.luthiersforum.com/forum/forum_posts.asp?TID=9528& amp;KW=%28pics%29#forumTop Making a Bridge (Pics) - Hesh http://www.luthiersforum.com/forum/forum_posts.asp?TID=9013& amp;KW=%28pics%29#forumTop Installing Side Markers (Pics) - Hesh http://www.luthiersforum.com/forum/forum_posts.asp?TID=8980& amp;KW=%28pics%29#forumTop Bias Tape Side Supports (Pics) - Hesh http://www.luthiersforum.com/forum/forum_posts.asp?TID=8545& amp;KW=%28pics%29#forumTop |
Author: | Kim [ Fri Jun 29, 2007 4:55 pm ] |
Post subject: | |
Here is a beauty Making a side profile template by ColinS http://www.luthiersforum.com/forum/forum_posts.asp?TID=7617& KW=side+profile#forumTop Cheers Kim |
Author: | bob_connor [ Fri Jun 29, 2007 8:12 pm ] |
Post subject: | |
OK. All of those have been added. Anyone got any more. Cheers |
Author: | Dave White [ Fri Jun 29, 2007 9:13 pm ] |
Post subject: | |
Bob, Great stuff. Anthony Z's headstock binding tutorial should be in - towards the bottom of here: http://www.luthiersforum.com/forum/forum_posts.asp?TID=9785& KW=headstock+binding#forumTop The "Correcting the Backbow" tutorial you have is linked to Joshua French's V joint tutorial. |
Author: | Sam Price [ Fri Jun 29, 2007 9:25 pm ] |
Post subject: | |
Excellent, Bob!!!! Thankyou!! |
Author: | bob_connor [ Fri Jun 29, 2007 9:28 pm ] |
Post subject: | |
Added that one Dave and fixed the Link. Cheers |
Author: | Cocephus [ Fri Jun 29, 2007 11:09 pm ] |
Post subject: | |
Thanks, Bob. You`re a real sport for doing this! Now maybe I can spend less time searching the archives! |
Author: | Anthony Z [ Fri Jun 29, 2007 11:48 pm ] |
Post subject: | |
Most excellent of you Bob for taking the initiative and thanks to Jebarri, Waddy, Kim and Dave for locating some other great ones! ![]() ![]() ![]() Alain Desforges did a nice one on binding the end of a curved fretboard that I can't locate. Wow there are some great tutorials in there. |
Author: | Brock Poling [ Sat Jun 30, 2007 12:27 am ] |
Post subject: | |
Maybe we shoudl include that circle cutting jig that Sylvan made up... I don't have the link handy, but I will hunt a little. |
Author: | charliewood [ Sat Jun 30, 2007 1:01 am ] |
Post subject: | |
Great Idea! ![]() This will really set the OLF head and shoulders above other forums on guitarmaking... People are enamoured with demonstrative pictorials relating to operations they wish to endeavour, as it were ![]() Cheers Charliewood |
Author: | jhowell [ Sat Jun 30, 2007 1:09 am ] |
Post subject: | |
Bob-- All I can say is ![]() ![]() ![]() ![]() This place is the most amazing resource I have ever come across. Thanks you all for being so generous with your talent and skill. |
Author: | WaddyThomson [ Sat Jun 30, 2007 1:57 am ] |
Post subject: | |
I wore my eyes out last night, but what I did was search on the title, using "(pics)", and browse. There are probably some threads that could be added, that weren't tutorial in nature, but that ended up being that as the entries came in. At the time, I was only looking for direct, "How to" threads. More time browsing will produce some more. |
Author: | L. Presnall [ Sat Jun 30, 2007 2:13 am ] |
Post subject: | |
Bob, on behalf of everyone...THANKS!!!! ![]() What a cool idea! If I ever get to build another guitar, I'll have all this great info at my fingertips! |
Author: | old man [ Sat Jun 30, 2007 2:19 am ] |
Post subject: | |
Thanks, Bob There's a great thread from two years ago on getting rid of armadillos. ![]() Ron |
