| Headblock dimensions http://luthiersforum.com/forum/viewtopic.php?f=10102&t=13727 |
| Author: | TommyC [ Fri Sep 21, 2007 6:19 am ] |
| Post subject: | |
Hello all. In the past I have used headblocks that were 2 1/2" wide by 2" thick. I use a straight m&t with barrels and bolts (cumpiano style). Because of some mahogany that I have around I was thinking about decreasing the thickness of my headblocks to 1 1/2" or so. What do ya think? |
| Author: | Don Williams [ Fri Sep 21, 2007 6:26 am ] |
| Post subject: | |
Sure, why not? Typically, a tenon is usually 3/4-7/8" deep, and so the slot can be within 1/8" of that. There's no reason at all why the wood behind it needs to be more than 5/8-3/4". Make the tenon 3/4", the mortice 7/8" and you're good to go. It wouldn't kill to make the M&T a little longer even. |
| Author: | TommyC [ Fri Sep 21, 2007 6:51 am ] |
| Post subject: | |
Thanks Don. The neck is already made with a 15/16" tenon. That would leave about 9/16" material behind the bolt head. Should be enough, no? I'm gonna go for it but anyone else please chime in because I would like to know what you thoughts are anyway. |
| Author: | Don Williams [ Fri Sep 21, 2007 7:00 am ] |
| Post subject: | |
There's not much reason to have the tenon 15/16". You can shorten it an 1/8" or so and still be fine, unless the dowel holes are already drilled... You need a good 1/16" to an 1/8" of gap behind the tenon in the mortice. You don't want the tenon bottoming out in the mortice. Even with a 1" deep mortice, you should have enough meat behind it to have the bolts be secure. Just make sure the grain is running the right direction on the block. |
