| Fret dressing time http://luthiersforum.com/forum/viewtopic.php?f=10102&t=14758 |
Page 1 of 2 |
| Author: | David Collins [ Sat Dec 01, 2007 5:00 am ] |
| Post subject: | |
I'm curious to see how much time others here invest in fret dressing, particularly in dressing worn or uneven frets as opposed to dressing a new instrument or a refret. For a new fret job of course, if the board is well prepared and the frets are well installed, there should be little leveling and as much as no re- crowning involved. This of course makes the polishing rather simple. If you have to take .010" off the top however of course re-crowning will be needed, leaving the sides in need of polishing. In the thousands of fret dresses I've done, I've tried and seen a plethora of different tools and techniques. If I really want that jeweler's mirror finish on the top and sides however, I've yet to find any method short of getting in there with your thumb, fingers, and sandpaper, and bringing them up to a polish grit by grit. While the leveling and recrowning may take as little as 10-15 minutes sometimes, I can often find myself spending twice as long or more on the final polishing. I'm essentially trying to justify my investment in a new idea for fret polishing that I stumbled in to while I was contemplating some old Gibson tooling marks. So far I've invested about $400 in tooling for this polishing system, and it may be promising with a bit more refinement. As of yet however, I haven't been able to get that perfect polish but I'm still hopeful. It's 90% there, to a point were probably 95% of the players wouldn't notice any difference without a jewelers loupe. Going through sandpaper, masking tape, steel wool, dry skin from compulsively washing my hands when polishing metals. I'd just like to get an idea how much of a thorn this is in other people's sides before I sink any more in to this project. Right now I can get that 90% quality in about 30 seconds without dirtying my hands, and am trying to figure out how much farther I can afford to go right now on this project that has already exceeded it's budget. Either that or if I should just get back in the trenches and keep sanding. |
| Author: | Kent Chasson [ Sat Dec 01, 2007 5:38 am ] |
| Post subject: | |
David, maybe you've tried this at some point but the time saver I'm fond of is the thin 3M sanding sponges. Because they conform nicely to the fret, the first grit will actually recrown all but the seriously flattened tops. I start with the "superfine" grit sanding perpendicular to the frets for light re-crowning. This also does a good job of taking off any sharp corners on the fret ends. I then do a pass with the same grit parallel to the frets, then move on to the "ultrafine" and "microfine". Then to the buffer. Although I've never timed myself, I'm guessing 10 minutes, maybe 15. The sponges are a bit spendy (between $1.00-$1.50 apiece) but it only takes 1/4 to 1/2 sheet of each grit per fret job. What's the system you are working on? |
| Author: | af_one [ Sat Dec 01, 2007 6:08 am ] |
| Post subject: | |
Its always been one of those things I just can't get up the level of quality I would like--I think I'm too impatient? I'd like to hear more about your system. |
| Author: | Ricardo [ Sat Dec 01, 2007 6:41 am ] |
| Post subject: | |
David, I use a polishing wheel on a Dremel. I use a product called GS27 Scratch Remover, a product intended for fixing scratches in auto paint. It takes scratches out of metal. |
| Author: | David Collins [ Sat Dec 01, 2007 7:16 am ] |
| Post subject: | |
Kent, I haven't used the 3M sanding sponges, but I will do essentially the same thing with double folded sandpaper on minor leveling and truing. The thing is that the vast majority of dresses I do are for moderate to heavily worn frets that will require a proper re-crowning and shaping after leveling. It's the parallel to fret, grit by grit, individual fret sanding to get the scratches toward the base of the side that has always been the big time soak. There's nothing complicated to what I'm doing - just some buffing arbors. My goal, and the tricky part is simply to find the right combination of wheels in the right order to be able to polish the board as a whole rather than fret by fret, preferably without having to mask the board. Rich, I've used a number of different wheels for the Dremel or Foredom, but have had a few issues. The main problem with many is that most wheels do not conform well enough to attack the sides of the fret without moving a disproportionate amount of material on the top, thus potentially effecting the level. That, plus I'd rather use a system with 6 or 8 inch wheels that allow me to run across the whole board rather than one fret at a time. I've not tried the Scratch remover you mention, but I've gone through a number of other compounds and wheels. I was hoping to perfect the system or at least refine it a bit more before posting it here, but I'll try to get some pics and details posted later this weekend with hopes of helpful tips via peer revue. I'm just really trying to streamline and simplify this procedure as much as possible. It may not be that big a deal to most, but for me polishing out a few dozen fret dresses a month can get tiring, and the time adds up pretty quickly. |
| Author: | Howard Klepper [ Sat Dec 01, 2007 7:49 am ] |
| Post subject: | |
As a repair person, I used to flat rate a "fret job" (level, crown, polish, restring, adjust nut and truss rod) at 2 hours. My methods haven't changed much in 35 years. I never watch the clock to time any of my processes, but two hours is probably still a fair estimate. I level with a 10" smooth mill file with the tang removed and ends ground soft. I used to then bevel the sides with a 10" cantsaw file ground safe on its corner and to one side of the 120? angle (for right handed use only). I now do this with one of the Gurian crowning files. I round the ends with a smaller (6") cantsaw file, similarly ground safe. I sand to complete the shaping and polishing. The sanding is tedious and gives me sore sides on my thumbs. Then buff after I get to 600 grit (CAMI). I'm now doing two buffs, first tripoli and then white rouge. I keep the board masked until the buffing. |
| Author: | Kent Chasson [ Sat Dec 01, 2007 8:30 am ] |
| Post subject: | |
David, the main benefit of the sponges is that I've found that they do conform and polish the sides of the frets much better than paper. But I can't imagine doing it without masking. I get them by the box to get the price down. I'll send you one of each grit if you want to give them a try. Send me a pm with your address if you're interested. |
| Author: | David Collins [ Sat Dec 01, 2007 2:32 pm ] |
| Post subject: | |
Thanks Kent. I may pick some of those up to try, but at this point I'm still pretty enthusiastic about making this system work. I've gotten pretty fluent and developed a fairly natural grip for good results with folded sandpapers at this point, but I'm always open to trying new tools. I appreciate the offer to send me some very much, but it would probably be just as easy for me to pick some up at the hardware or Grainger. Thanks again. And Howard, your technique and time doesn't vary too far from mine. I've tried plenty of shortcuts, but have yet to find a technique that delivers the same quality of result - until now that is .
Well, that's not entirely true of course, but I'm still a bit optimistic that I can improve on this method and make it work. It's closer so far than any thing else I've tried anyway, and even if it doesn't become a 30 second full polish I know at this point that I should be able to cut a fair amount of time. I'll try to get some photos tonight and post a bit more later. |
| Author: | grumpy [ Sat Dec 01, 2007 4:33 pm ] |
| Post subject: | |
I can't imagine life without the StewMac fret polishing wheels. Those little suckers, once you grind them to the shape of a fret top, bring them up to a great polish in no time. Only caveat is that they will also heat up the frets very quickly, so I move quickly over the fret, moving to the next one within the second, and even wait between "passes". Rolling off the ends also takes care of that bit... No way I spend near 30 minutes polishing... |
| Author: | grumpy [ Sat Dec 01, 2007 4:35 pm ] |
| Post subject: | |
Arghh.. December... still no f*#%*ng edit button... I should ad that if your system can beat theirs, I'll get in line for one. There's always room for improvement.... |
| Author: | David Collins [ Sat Dec 01, 2007 5:01 pm ] |
| Post subject: | |
I agree that StewMac's polishing wheels are excellent. It's always been the heating you mention that's worried me though, for risk of moving too much metal. They're great, but they definitely take a knowing and qualified hand to operate to avoid ruining the level of the frets or rolling the ends as you mentioned. I just went over to the shop to take some photos and try another neck, and think I worked out some of the bugs. Now bear with me while I shamelessly write one of my Ken Burns-length documentaries on the development of my favorite new toy. I'll start a
new topic. |
| Author: | Rick Turner [ Sat Dec 01, 2007 5:34 pm ] |
| Post subject: | |
I'm right in there with Kent and Howard on stuff other than my "unpatented" under string fret leveler "L" system that takes care of anything short of major 100,000 miles past due levels which is where I go for the smooth mill file. By the way, do not trust the flatness of any commercial files. You have to go through a box of 20 of them to find two or three that are truly flat. Don't even bother buying mill basard or mill smooth files mail order; they're all cattywhumpus. You're better off using a precision ground length of steel or plate glass with sand paper stuck to it. The 3M stuff is miraculous, and it lasts a long time. There are grits that seem to go up the the equivalent of about 800. |
| Author: | David Collins [ Sat Dec 01, 2007 6:20 pm ] |
| Post subject: | |
So here I go again with a very drawn out narrative of development of my favorite new tool. Have fun. I'll have to split this up in to several posts, so bear with me. I’ve always been conscious of the tooling marks left on Gibson fret boards from the teens through at least the 60’s, and been careful to preserve them in fret dresses for some sentimental reason. I had always assumed that they were from the machining of the board, though the direction of the markings seemed counterintuitive. It wasn’t until a recent 30’s Gibson refret that I really noticed how markedly high the plateaus were that the frets rested on were, beneath which the board was clear of markings. I tried thinking of several ways of sanding, filing, etc., that the markings could have been made post fretting, but none made sense at all to be a Gibson factory procedure. Finally it occurred to me that they had to have buffed the frets and unprotected board with a very course wheel in what little dressing process they used. I went through a few different wheels trying to mimic it, and finally settled on a fine (.008”) crimped wire wheel. Following this with an aggressive buffing on a wheel with tripoli compound was enough to polish the wire markings from the frets, leaving the board looking perfect vintage Gibson. Duh. Crude, quick, effective. “Good enough” in a nutshell for the period Gibson factory instruments. |
| Author: | David Collins [ Sat Dec 01, 2007 6:22 pm ] |
| Post subject: | |
Here's a few examples 10's
20's
30's
| Author: | David Collins [ Sat Dec 01, 2007 6:24 pm ] |
| Post subject: | |
40's
50's
60's
| Author: | David Collins [ Sat Dec 01, 2007 6:26 pm ] |
| Post subject: | |
And it wasn't limited to Gibson. And of course even more crude would be the Chicago instruments. Here's a Supertone
And a Harmony, from the same factory I'm sure.
| Author: | David Collins [ Sat Dec 01, 2007 6:27 pm ] |
| Post subject: | |
So while browsing Grainger for a decent 6”-8” wheel to put on a grinder to mimic this on occasion, I stumble across 3M’s “radial bristle” wheels. Thanks to being introduced to these by the goldsmiths upstairs, I’ve been using the tiny Foredom sized ones for metal polishing for a few years, but never realized they were made in 6” and 8” sizes. The beauty of these tools is their flexibility, and ability to conform to the shape of a fret without putting any disproportionate pressure directly on the top. These were only introduced about 6 years ago, but with the little experience I had with them I thought it worth a shot to see if they could perform a Gibson-style fret polishing with less damage to the fingerboard. So to save space I picked up some good shafts and bearings and set up a stacked arbor. Not the most ergonomic, but you do what you have to when space is limited. It’s still temporarily screwed to an old bench in the “under construction” section of the shop, so don’t hold the mess against me. |
| Author: | David Collins [ Sat Dec 01, 2007 6:31 pm ] |
| Post subject: | |
So here's most of my fret dressing tools.
| Author: | David Collins [ Sat Dec 01, 2007 6:34 pm ] |
| Post subject: | |
I use the files for course leveling, but really like the float glass planes for final truing. Since I can level the glass on my surface plate I have a lot more control over their quality than with files, and like being able to choose grits. In this example I’ll show the long plane was fit with 120 grit for course leveling. Then 300 grit diamond file crowing, then the shorter plane with 220 for a second tighter truing. In the spirit of plate leveling from machinist days, I will sometimes repeat this procedure several times at lighter grits and pressure to reach tighter tolerances with each round. Here’s the leveled and crowned fret. My apologies, but I don’t have the camera, lighting, or skill to get a good macro shot of metals, so take these photos for what they are.
| Author: | David Collins [ Sat Dec 01, 2007 6:35 pm ] |
| Post subject: | |
In experimenting with the buffing system I tried the 120, 220, 400, and 6 micron radial bristle wheels, along with cloth wheels with jewelers rouge and with tripoli. The 220 wheel (spinning at around 2800rpm) was not aggressive enough to easily get out the 220 grit from the final leveling plane. Maybe some CAMI / FEPA conflict, I don’t know. I could get it out if I really hogged in to the wheel, bet it ended up leaving a slightly stippled look to both the wood and the frets, which the 400 would not get out. The 120 wheel would take out the 220 leveling scratches, but grooved the fingerboard noticeably. So what I’ve ended up doing is quickly kissing the tops with a bit of 320 sandpaper before approaching the 220 wheel. I run the board along the wheels from the center to off the edge, tilting the neck to hit the frets at a slight angle one way, and then shifting to the other to get both sides well enough. Then I flip the neck around to roll off the opposite side, as in bass or treble sides. I initially had problems with each successive wheel fully removing marks from the previous grit, as though there were too big a gap between grits. Finally I started taking a series of lighter passes on each wheel before moving to the next grit. 220 heavy, 220 light, 400 heavy, 400 light, 6 micron heavy, 6 micron light. 0000 Steel wool, then wax. So far this seems to work beautifully. |
| Author: | David Collins [ Sat Dec 01, 2007 6:36 pm ] |
| Post subject: | |
This neck photographed didn’t really need a dressing, but it was one of the few expendable necks I had left around which hadn’t already had the board ravaged in other experiments. Here’s the before board.
And here's the after.
| Author: | David Collins [ Sat Dec 01, 2007 6:43 pm ] |
| Post subject: | |
No tooling marks, no notable rolling of the edges, no rolling of the fret ends at all. From finishing of the filing to the waxing of the board takes under a minute. There may be a bit of a learning curve with these wheels as well, but so far it seems like a system with potential. At $50+ per wheel, they’re not terribly cheap, but if you do any amount of fret dresses they can pay for themselves in saved time pretty quickly. This may very well be old news, I don’t know if some factories are already doing something similar. Rick may also know something about the old Gibson fret dresses that I don’t know as well. In any case, I’m pretty damned geeked about this as it’s going to save me oodles of time. Just make sure if anyone comes up with any improvements or refinements (of which I'm sure there are several to be had), let me and everyone else here know about it. I've only played with this in my "spare time" over the last few days as of yet, so it certainly may change. |
| Author: | Rick Turner [ Sat Dec 01, 2007 6:48 pm ] |
| Post subject: | |
Well, in the first place, Gibson fingerboards and fret work has traditionally been among the worst ever in the guitar industry. If any company consistently got it wrong decade after decade, it was them. I'll take a run of the mill 1962 Harmony fingerboard over most Gibbies any day. Then, if you want that high shine on the frets, just mask off the 'board between the frets and do your level and crown and 3M sanding sponge work, and then put it on a 10" wheel buffer with emery and then Tripoli buffing compound. Somehow, I've managed to collect more double arbor buffers here than we know what to do with, so having one just for frets isn't an issue. The 'board should never ever show evidence of cross grain sanding, buffing, scratching, scraping or anything once the job is done. We Waterlox our fingerboards at least a day before we fret them. It makes for a really nice surface that you just don't want to screw up, so masking between frets is just normal for us. |
| Author: | David Collins [ Sat Dec 01, 2007 6:52 pm ] |
| Post subject: | |
Another nice thing is that these wheels won't tear through masking tape unless you really bear in to them. I'm hoping this means they will still be useful for finished and maple boards. |
| Author: | David Collins [ Sat Dec 01, 2007 6:59 pm ] |
| Post subject: | |
Oh, and Rick, I definitely agree with you about the quality of Gibson's fret work over the years. The main reason I ever wanted a way to replicate it was simply out of curiousity. Also for the occasional vintage fanatic customer who wants everything down to the shameless flaws replicated. I try not to cater too much to folks who put frivolous and counterproductive details priority over function, but I always at least like to know I could do it accurately if I wanted to. |
| Page 1 of 2 | All times are UTC - 5 hours |
