HELP:: Fixing my boneheaded mistake http://luthiersforum.com/forum/viewtopic.php?f=10102&t=5686 |
Author: | Brock Poling [ Thu Mar 16, 2006 5:13 pm ] |
Post subject: | |
I am in need of a little clever thinking. I was cooking up a batch of telecaster style necks tonight. I inlaid the carbon fiber, truss rods, drilled the access hole, trimmed and profiled them and was cooking along nice. I usually work with really thick stock then remove stock from the back with my sander and 36 grit to bring me into the neighborhood where I can begin to carve the shaft of the necks. Everything was working out fine until I stuck one of the necks in the sander face up!!! (Shows you what I get for working late....) Now the truss rod channel is too shallow by about 1/32 of an inch. Any idea how I can deepen that channel now that I have the neck profiled to its final shape? And ... to top it off I use the SM hot rods and they use an unusual size bit... |
Author: | Daniel M [ Thu Mar 16, 2006 5:55 pm ] |
Post subject: | |
I made a narrow scraper out of a piece of .042" band saw blade just a hair narrower than the slot. After rounding the business end on the bench grinder, there was a nice wire edge around the tip that made material removal at the bottom of the slot quick & easy. I rounded the edges of the tool, so it wouldn't damage the slot sides. Any stiff piece of steel should do if you don't have heavy band saw blades. I have an old set of rusty feeler guages I find useful for making special scrapers & all kinds of other tools. The forty or fifty thou one would probably make a great slot scraper. If you make full length passes, the bottom should stay very flat, but it's good idea to do a check with a straight edge after a couple of passes & work down the high spots if they develop. |
Author: | Rod True [ Thu Mar 16, 2006 6:22 pm ] |
Post subject: | |
Brock, is the back of the neck profiled? If not, you could make a tapered piece, same as the taper on one side of the neck to create a reference edge parallel with the centerline of the neck, "tack" it in place, re-route your channel than cut the ledge off. That should work, if the back of the neck is still "squarish". If not, who knows ![]() |
Author: | Brock Poling [ Thu Mar 16, 2006 11:45 pm ] |
Post subject: | |
the neck is still flat, but profiled to shape. |
Author: | TonyKarol [ Fri Mar 17, 2006 12:11 am ] |
Post subject: | |
I used to route channels with a long slotted jig - take a 1x3, route a 3/8 slot down the centre on your router table - not all the length - you need to leave a couple inches at each end. Now you can clamp this to the neck, use a 3/8 template guide in a router base and the proper bit in the router. You will likely have to route it in sections as you move the clamps holding it to the neck. |
Author: | Mike Mahar [ Fri Mar 17, 2006 12:34 am ] |
Post subject: | |
I did something just like this last week. What I did was to stick a 1/4" piece of plywood to the top of the neck with double sided tape. The existing truss rod slot was lined up parallel with the edge of the plywood. The edge of the plywood then ran along the fence of my routher table Double sided tape is more than strong enough to hold the neck firmly to the board. See crude drawing. ![]() |
Author: | Dave-SKG [ Fri Mar 17, 2006 1:02 am ] |
Post subject: | |
How bout some pics Brock? |
Author: | Mark Swanson [ Fri Mar 17, 2006 1:27 am ] |
Post subject: | |
You could also just use a different type of trussrod for that neck. Make yourself a Gibson-style single rod, and then you'll have room. |
Author: | Brock Poling [ Fri Mar 17, 2006 1:56 am ] |
Post subject: | |
Thanks guys.... solution found. I use a cochran base to install these in the raw stock, so neck stuck to the board trick will work beautifully. I just need to match the centerlines and presto... Thanks. |
Author: | Rod True [ Fri Mar 17, 2006 1:59 am ] |
Post subject: | |
Or you could do this, some what similar to Tony K's idea Use a piece of MDF or Plywood as thick as you can get it, say 5" wide by the length of the neck plus 5-6 inches. On one side, mark out the exact taper of the neck (both sides) and cut out a channel (say 1/4" deep) to the taper, Now route out a section down the middle, leaving the ends solid of course, flip it over and double side tape to the neck, route away. What you need is a reference to the centerline of the neck right. |
Author: | Keith M [ Fri Mar 17, 2006 12:44 pm ] |
Post subject: | |
Brock, What I did for this was I made a short square wooden bar that just fit the slot and glued it to a temporary wooden base double back taped to the base of the router with the bar in line with the bit.Drop it in the slot and route as deep as needed. |
Author: | Serge Poirier [ Fri Mar 17, 2006 2:33 pm ] |
Post subject: | |
Good luck with it Brock! |
Author: | Brock Poling [ Fri Mar 17, 2006 5:00 pm ] |
Post subject: | |
I made up a board as discussed and it worked like a champ. I am back in action on these necks. ![]() |
Author: | Serge Poirier [ Fri Mar 17, 2006 5:02 pm ] |
Post subject: | |
Way to go Champ! ![]() |
Author: | Rod True [ Sat Mar 18, 2006 3:23 am ] |
Post subject: | |
Well done, like they always say, a good woodworker makes few mistakes, a great one knows how to fix em'. |
Author: | John K [ Sat Mar 18, 2006 4:24 am ] |
Post subject: | |
I would have been tempted to rout a 1/32 inch channel in the bottom of the fingerboard. Keeps that truss rod channel from getting so close to the bottom of the neck. I always worry about not having enough material in that region, especially with those SM hotshot truss rods, they are so deep. John |
Author: | peterm [ Sat Mar 18, 2006 7:46 am ] |
Post subject: | |
Brock, after my fingerboard disaster I know exactly how you feel ![]() ![]() buty with your skills I'm sure you'll make it right! |
Author: | Don A [ Sat Mar 18, 2006 8:56 am ] |
Post subject: | |
Brock, glad it worked out for you. What I was going to suggest is gluing on some layers of black and white (or whatever color you choose) veneer. Then use a patttern bit to cut out the channel in the veneer. That would give you some height back and add a decorative perfling below the fingerboard. |
