Blanket question http://luthiersforum.com/forum/viewtopic.php?f=10102&t=5873 |
Author: | Phil Marino [ Wed Mar 29, 2006 1:29 am ] |
Post subject: | |
I just finished my bending form, and I'm looking to buy a blanket, and trying to figure out what's best to get. Some of you have talked about blanket (or wood?) temperature during bending. How do you measure the temperature? Is there usually a temperature probe inside the blanket? Or, is there a separate temperature sensor that the controller uses? It seems like it would be hard to measure the temperature of the blanket/sides without a sensor right in the blanket. If you stuck some kind of sensor outside the wood/blanket/slat sandwich, you might not get the real wood temperature. So, if possible, I'd like to get a blanket with a sensor inside. I could use it to monitor the temperature, at first, and maybe add a temperature controller in the future if it would help. I do have a big (1500 watt) dimmer I can use to control the power to the blanket, and a timer. The only blanket I can find on the web is from LMI. Does anyone know if their blanket has an internal temp sensor? Any other recommendations as far as who and where to get a blanket (and what to look for? Thanks for any advice or comments, Phil |
Author: | Brock Poling [ Wed Mar 29, 2006 1:31 am ] |
Post subject: | |
The latest issue of Guitarmaker (#55 for those of you following along) has detailed instructions, parts lists, etc. for how to build a true temperature control unit. |
Author: | Pwoolson [ Wed Mar 29, 2006 1:43 am ] |
Post subject: | |
John Hall at BluesCreek has blankets. Also Omega Engineering has them but there is often a long wait. None have a temp sensor built in but you can go to Omega with part # CO3-J which is a cement on thermocouple. The article that Brock talks of is worth the price of membership if you aren't already an ASIA member. |
Author: | Tim McKnight [ Wed Mar 29, 2006 3:15 am ] |
Post subject: | |
I use Minco blankets and have been quite happy with their performance. They have fast shipping and have many custom sizes and wattages available. |
Author: | Brock Poling [ Wed Mar 29, 2006 5:29 am ] |
Post subject: | |
The rheostat works ok, but just to be clear... the thing in the ASIA journal is a TEMPERATURE CONTROL UNIT. You can dial in a temperature and it will maintain that setting. Very slick. |
Author: | tippie53 [ Wed Mar 29, 2006 10:12 am ] |
Post subject: | |
The ASIA control is nice design. The investment in time is worth it. I may have to build them myself. The set up I came up with was affordable and relyable. Wood bending isn't rocket science. If you would like some instructions send me an email tippie@epix.net and you can get a copy john hall |
Author: | burbank [ Thu Mar 30, 2006 1:26 am ] |
Post subject: | |
To add to what Brock is saying about the ASIA journal unit is that it has a thermocouple and thus a feedback loop where the actual temp is fed back to the unit to let it know when to turn off and back on. |
Author: | Anthony Z [ Thu Mar 30, 2006 3:03 am ] |
Post subject: | |
[QUOTE=Pwoolson] Omega Engineering has them but there is often a long wait. None have a temp sensor built in but you can go to Omega with part # CO3-J which is a cement on thermocouple. [/QUOTE] Paul is there a companion Omega or other manufacturer temperature controller you'd recommend? |
Author: | Don Williams [ Thu Mar 30, 2006 3:15 am ] |
Post subject: | |
Watlow also makes controllers and sensors for their blankets that are programmable, so you can set it to heat up to a temperature, hold for given time, and then cool down to another temp and hold for time, at least I'm pretty sure they do that. I imagine they aren't cheap though. |
