| Side Grain Rosettes http://luthiersforum.com/forum/viewtopic.php?f=10117&t=16350 |
| Author: | Ken Franklin [ Mon Mar 10, 2008 10:36 pm ] |
| Post subject: | Side Grain Rosettes |
This is what I do side grain rosettes. I've gotten tips from Al Carruth and William Cumpiano and I've come up with what works for me. I start with cutting strips of veneer across the grain. These can be flimsy so you have to handle them carefully. It's nice if these are 7-8 inches long, but you can make shorter logs and use two. Attachment: RosetteVeneersWeb.jpg I do the same with the cutoff ends of backs. These might be cut in different shapes. Attachment: BackCutoffsWeb.jpg Then I glue the veneer strips and/or cutoff strips together with gap filling CA. I like the low odor stuff. Attachment: InitialGlueUp.jpg I might saw these initial glued-up strips in different shapes or not, but then I glue them together to make a log. Attachment: LogsWeb.jpg Then I sand the edges and try to put in the taper that will fit the tiles in a circle. I slice about three of the tiles on a band saw by holding the log against the fence pushing it through with a push board. Attachment: CuttingTilesWeb.jpg Then I cut out a channel in my top and try them out. If the taper is good, I cut the rest of the tiles, otherwise I make adjustments. I like to number them and keep them in order. I sand the bottoms flat. Then I start gluing them in the channel. I use LMI white to glue them in but whatever you use to glue in your rosettes will probably work. I hold the tiles down with my drill press until the glue grabs. I made a little caul that fits in my fly cutter, so I can do the whole operation at once. Attachment: Clamping Rosette Web.jpg After they are all glued in place, I cut the the groove for the outside arc of the rosette with a bit the size of the purfling I want to use. That cleans up any irregularities I might have. Then I cut out a hole for the inside arc which I bind. I put in my purfling and I'm done except for the usual scraping. I used polygon tiles for my endless martini rosette. Attachment: RosettetilesW.jpg Attachment: MarionRWeb.jpg
| Author: | Dave Higham [ Tue Mar 11, 2008 4:00 am ] |
| Post subject: | Re: Side Grain Rosettes |
Excellent tutorial Ken. You're going to get a lot of people thanking you for that one. |
| Author: | WaddyThomson [ Tue Mar 11, 2008 9:29 am ] |
Very nice tutorial Ken. Easy to see and understand. Thanks for posting it.
| Author: | Rollo [ Thu Mar 13, 2008 5:29 pm ] |
Beautiful work Ken, thank you for for sharing. Aloha, Rollo |
| Author: | KenH [ Tue Apr 01, 2008 12:54 am ] |
Beautiful rosettes Ken! Thanks for sharing your efforts! This gives me all kinds of ideas on building my own now |
| Author: | Chris Paulick [ Mon Sep 22, 2008 8:17 pm ] |
Thanks for sharing that with us. I've been wanting to try something like. |
| Author: | DGr33n [ Mon Apr 13, 2009 3:12 am ] |
Thank you very much for sharing, I look forward to learning here at OLF |
| Author: | DGr33n [ Mon Apr 13, 2009 3:13 am ] |
