| Hand neck carving - holder for blank http://luthiersforum.com/forum/viewtopic.php?f=10117&t=26349 |
| Author: | Colin North [ Thu Mar 04, 2010 6:30 am ] |
| Post subject: | Hand neck carving - holder for blank |
I have never seen anything like this suggested in books or tutes, and was less than impressed with what was used during my class. Now I have set up shop, I came up with this , and thought newbies might find it useful. I glue the fretted fingerboard to the bolt-on Mortice and Tenon neck first, but that's me. This holds a blank securely, suits different scale lengths and head angles (head support pivot on screws into main body), gives access for shaping heels and head flares, and can be used to secure the neck on its side as well as inverted, useful for working of the fingerboard edge area. Overall height of the main part is about 7.5 inches, width at fretboard area is about 1 1/2"". I use a workmate to secure the holder as I find it easy to move around, but it can also be held in a vice or secured to a bench. See what you think. |
| Author: | Joe Sustaire [ Thu Mar 04, 2010 8:27 am ] |
| Post subject: | Re: Hand neck carving - holder for blank |
Very cool Colin! I'll have to build one of these, looks like it does the job well and is simple to build. Thanks for sharing, Joe |
| Author: | Ken McKay [ Thu Mar 04, 2010 9:21 am ] |
Nice jig! Thanks for posting. |
| Author: | Arnt Rian [ Thu Mar 04, 2010 9:32 am ] |
Nice! How do you keep that part where you clamp the head from pivoting, once it is adjusted for the headstock angle? Is there a wing nut or something we're not seeing in the pictures, or...? If it is not secured, how does it support the headstock? |
| Author: | thomas west [ Thu Mar 04, 2010 10:40 am ] |
I'm not speaking for Colin but I have one similar to this and use a hinge as the pivot point.The clamp is enough to hold the headstock.Once the neck is clamped with the two clamps it's as solid as needed.Nice job Colin,your is nicer then mine. Tom |
| Author: | Colin North [ Thu Mar 04, 2010 5:14 pm ] |
thomas west wrote: I'm not speaking for Colin but I have one similar to this and use a hinge as the pivot point.The clamp is enough to hold the headstock.Once the neck is clamped with the two clamps it's as solid as needed.Nice job Colin,your is nicer then mine. Tom You answered than quite nicely actually! I did think of using a hinge, but opted to clamp the head holder to the head of my first neck, postion it to see how it fell, and then put the screws in. Thanks for the compliment Tom, mine's actually a bit rough (as most of my first built jigs'n things!), but does the job OK. Colin |
| Author: | Rob Warren [ Thu Mar 04, 2010 6:53 pm ] |
built one similar after I toured the Martin museum. Works great! |
| Author: | Colin North [ Fri Mar 05, 2010 4:02 am ] |
Rob Warren wrote: built one similar after I toured the Martin museum. Works great! There's nothing new....... Any chance of a pic? If yours was inspired by Martin tour and mine is similar, I must have done something right!
| Author: | Chris Paulick [ Mon May 21, 2012 7:26 pm ] |
Nice, I'm going to make me one.
| Author: | Jim Watts [ Mon May 21, 2012 7:44 pm ] |
I have one of these too, I think it's in Bob Benedetto's book. Colin's is nicer than mine too. |
| Author: | surveyor [ Sat Nov 11, 2017 7:10 pm ] |
Made this one out of an old oak table found on roadside. Also used the table for 2 backs and sides sets. Had to pad the bolt and wingnut. |
| Author: | Ruby50 [ Sun Nov 12, 2017 10:38 am ] |
I built the same jig. I found a piece of a glue-lam (laminated structural beam) at a house construction site - while picking up some framing lumber scraps for jigs and such. It is 1-3/4" thick. The holes at the first and 10-12th fret are 1" from the top surface for easy addition to measure the thickness of your neck blank - others have shown that feature. It has a 1 X 1 screwed on that is a stop to quickly stick it in the vice. It is long enough that it fits in that corner vice and allows great access from a stool on the left. I made the holes wide enough that they can handle a 12 and 14 fret neck of various scale lengths. The stop at the heel is to keep the blank from moving to the left. Ed |
