| Bought a kit with wrong Neck http://luthiersforum.com/forum/viewtopic.php?f=10122&t=40085 |
| Author: | Jurgen [ Wed Apr 17, 2013 5:34 am ] |
| Post subject: | Bought a kit with wrong Neck |
Hi, my name is Juergen and I´m addicted to guitars. I started to think about building a guitar quite some time ago, and I finally did it. I bought a prof. kit for a classical from Madinter.com. My intention was to build it with a bolt on neck (see http://liutaiomottola.com/instruments/Cincia.htm) and the kit I wanted to buy includes a neck and a heel blank. During I already started to build a mould ... When I received the package I found a finished neck in the classical style. I checked my order and it was my mistake, I ordered the wrong kit. Is there any way I can use (alter) this neck for the bolt construction? Or do I have to buy a neck blank Any input is apreciated. |
| Author: | John A [ Wed Apr 17, 2013 7:19 am ] |
| Post subject: | Re: Bought a kit with wrong Neck |
If you are doing a butt joint - you can simply cut the neck block off, you will then have the neck with a shaped heel. You can drive nut inserts into the heel and use the cut wood to make a neck block which you would glue to the inside of the guitar. Or... you could just pick up some neck wood a 3/4" x 36" x 3" will get you enough for a stacked heel, neck, headstock, and neck block. |
| Author: | Dave Sayers [ Wed Apr 17, 2013 7:59 am ] |
Can't you return the kit? In any case, a little research into fitting dovetail necks shows that they aren't THAT hard to do, just m,ake sure you shim it out, and leave a gap for steaming in case a neck reset is needed. |
| Author: | Jurgen [ Wed Apr 17, 2013 8:29 am ] |
@ John: I wasn´t sure if it´s possible to do it this way. Sounds like the easiest way. @ Dave: Nope, noch chance to return it. By the way: it´s not a dove tail neck. It´s a classical neck where neck and neck block are one piece |
| Author: | Freeman [ Wed Apr 17, 2013 8:59 pm ] |
What you have bought is a classical guitar (gut or nylon string) kit. They do not have bolt on necks - almost always Spanish heel. If you want a bolt on neck steel string guitar, buy a different kit - yours will have many parts that are not compatible with steel strings. If you want a classical guitar, built the kit that you have, use a solera or mold that will handle the Spanish heel - don't try to modify it. You can of course cut the neck off like resetting an old Yamaha, but that would be the wrong thing to do with the kit that you have. |
| Author: | Jurgen [ Thu Apr 18, 2013 12:36 am ] |
@freeman: Yes, I know. And you´re right, normally classical guitars are not build with a bolt on neck. When I found the plans for the nylon string with bolt on neck (see: http://liutaiomottola.com/instruments/Cincia.htm) I thought it would be nice to have something which is unsual. I have at least 2 examples for such a thing: you can find 2 classical guitars with bolt on neck on Kathy Matsushitas web site and the one from the link above. |
| Author: | FishtownMike [ Sun Apr 28, 2013 11:42 pm ] |
I actually looked at this kit and it has a neck and a neck block that are separate unlike the tradition style one piece neck and block assembly. It's actually a dovetail neck and not the traditional classical style neck. You would have to make a new block and cut the dovetail off but it is doable.
| Author: | Jurgen [ Tue Apr 30, 2013 9:52 am ] |
perhaps it is better to explain what I received: 4-5mm raw blanks for top and back, the same for the sides, two blocks of spruce (to make the bracing myself), raw fingerboard, raw bridge, several peaces of 0,6mm veneer (don´t know what its good for, but in the shop it said rosewood binding, which i couldn´t find), a classical neck (almost finished)... => it´s not really a kit, but you get the material to build a guitar almost from scratch |
| Author: | Freeman [ Tue Apr 30, 2013 12:06 pm ] |
Jurgen wrote: => it´s not really a kit, but you get the material to build a guitar almost from scratch Did you get plans and instructions? |
| Author: | Jurgen [ Tue Apr 30, 2013 7:43 pm ] |
Nope! I knew this before, but I didn´t expect the kit to be a "raw" kit. That´s one of the the reasons I wanted to take the plans from the link mentioned nin the first post. To build from this "kit" will be a bigger challenge (I hope not too big) |
| Author: | Freeman [ Thu May 02, 2013 11:13 am ] |
Jurgen wrote: Nope! I knew this before, but I didn´t expect the kit to be a "raw" kit. That´s one of the the reasons I wanted to take the plans from the link mentioned nin the first post. To build from this "kit" will be a bigger challenge (I hope not too big) That is what is called an "unserviced" kit - LMI and others puts together all the wood and parts that you need but doesn't do any of the work. "Serviced" kits have at least some of the work done - plates are final thickness, sides bent, fretboard slotted, maybe the rosette is installed. These tend to be the operations that require special tools or are easy to screw up (or both). In my experience plans and sometimes a video or other instructions are usually included. http://www.lmii.com/products/mostly-woo ... ument-kits What I am assuming from your posts is that you did not buy the kit from Mottola but want to use his plans. That would explain why your neck is wrong - as I said before most classicals use a Spanish heel and his plans are for his own design. My humble suggestions would be to either sell what you have and buy his complete kit or build a conventional classical out of what you have. There are many good plans and instructions - Cumpiano's book would be a good start as would LMI's plans for the 1937 Hauser. Good luck |
