| Cracked glue joint on soundboard http://luthiersforum.com/forum/viewtopic.php?f=10122&t=43300 |
| Author: | Mike Mattox [ Fri Apr 25, 2014 12:12 pm ] |
| Post subject: | Cracked glue joint on soundboard |
Hi everyone, This is my first guitar build attempt. I jointed my top plates and glued them together with tite bond original about three weeks ago. Plates are thicknessed to 1/8". I've cut out the rough outline. I discovered today that the glue joint separated for about three inches on the face side but not quite as far up on what is to be the inside. How would I go about repairing this? Can it even be repaired? I don't know how I would even clamp it since the outlines already cut out. Could I just try to get as much glue down into it from both sides as I can then stretch tape across for a little clamping pressure? Should I just cut it in half and re-joint? Everything was going great up to this point! Sent from my iPhone using Tapatalk |
| Author: | Mike Mattox [ Fri Apr 25, 2014 2:37 pm ] |
| Post subject: | Re: Cracked glue joint on soundboard |
I discovered the search bar and found an explanation of what to do |
| Author: | B. Howard [ Sat Apr 26, 2014 7:34 am ] |
Welcome to the forum and glad we could help. |
