Solid Body Blank Thickness
http://luthiersforum.com/forum/viewtopic.php?f=10123&t=32025
Author:  forgottenwoods [ Thu Apr 28, 2011 8:38 pm ]
Post subject:  Solid Body Blank Thickness
Most solid body blanks are offered as 1-3/4" thick.
When used as a book matched back with a 1/4" thick drop top is 1-3/4" thick necessary?
I am cutting body sets from our Peruvian wood and would like to hear your opinions of the actual thickness needed.
It seems to me that 1-3/4" thick is correct for a solid body without the drop top plate?
So please tell me your opinions and what you prefer. I don't want to cut thicker than needed.
Just as an example here is a set I recently cut. What you see represents the back of the guitar.
Author:  alan stassforth [ Thu Apr 28, 2011 8:55 pm ]
Post subject:  Re: Solid Body Blank Thickness
Umm, i think that piece of wood would be a cap.
It's lovely.
I like thin guitars,
1- 7/16", so, if I had that piece, I wouldn't bother laminating it.
Wish I had some money.
What is it, anyway?
I would say, for me, if I wanted body filler, for the back,
1-1/4" would be good 4 me.
Too nice for a back.
I'm strange though.
Author:  forgottenwoods [ Thu Apr 28, 2011 9:06 pm ]
The wood is Spalted Yellow Pashaco.
This set is cut at 1-1/2" thick.
I agree it is pretty enough for a top but I am thinking that guitar backs should be pretty too!
This species is light weight at about 36 pounds per cubic foot and has a good tonal response.
So my idea is a nice light weight body capped with an even more beautiful plate of a denser wood.
Thanks for the input on thickness at 1-1/4".
Author:  alan stassforth [ Thu Apr 28, 2011 9:51 pm ]
So, how much do you want for that piece of kindling?
Also, what is the length and width?
I went to your web-site, and couldn't find it there.
Author:  theguitarwhisperer [ Thu Apr 28, 2011 10:55 pm ]
I would use that for a back and if you had quartered lumber necks too. For a Les Paul style guitar it would need to be 1 5/8ths inches thick.
For joined and finished blanks ready for bandsawing I would make them 1 3/4ths inches thick for teles and strats and 1/58ths thick for Les Paul blanks ready to receive caps. For lumber I'd leave it at the 1 7/8ths surfaced 2s 8/4 thickness.
Author:  forgottenwoods [ Fri Apr 29, 2011 7:31 pm ]
Filippo Morelli wrote:
I like the way you think, Lance.
Filippo
[:Y:] Yeah, we want um pretty coming and going!
Author:  forgottenwoods [ Fri Apr 29, 2011 7:41 pm ]
I have not had time to get the new batch listed on the web-site. I can either cut wood or sit at the computer, and I am having way to much fum cutting this spalted wood. bliss
I would imagine it will price at about $150. If you are interested in it pm me.
It is oversize for a solid body set 17" x 22" and just shy of 1-1/2" thick. Plenty of room to play with.
Author:  forgottenwoods [ Fri Apr 29, 2011 8:03 pm ]
We have some quartered neck blanks. Mike Baranik has carved some necks from it and likes it a lot. I'll see if I can find a picture of one.
And then on the 1-5/8" thick back you would add 5/8" thick plate for the Les Paul style?
I don't think it would be good for bodies without a top plate because the back sides often don't come close to matching. Here ia a picture of what the back side looks like.
Actually now that I look at it, it might make a pretty interesting face, kind of a split personality.
We won't be offering this wood as lumber, everything is milling into Luthierie sets and blanks
Thanks for the 1-5/8" thick reference. This is the kind of info I like to hear. I don't like cutting everything to a standard size and then having you builders have to waste wood to get it the thickness you need.
Author:  HaMMerHeD [ Fri Apr 29, 2011 9:16 pm ]
Asymmetrical wood/finish is definitely cool...
http://www.ritter-instruments.com/item_info.php?i=375
Author:  forgottenwoods [ Sat Apr 30, 2011 11:59 am ]
Absolutely beautiful!
Thanks for that link, I'll have to keep this in mind, I like offering unique wood selections.
