My First Carved Top
http://luthiersforum.com/forum/viewtopic.php?f=10123&t=32824
Author:  Ommadon [ Sun Jul 10, 2011 9:35 pm ]
Post subject:  My First Carved Top
I finished up my first carved top body today, i think it came out fairly well. I used the topigraphical routing and sanding technique. The guitar is getting close.
Author:  cactus [ Sun Jul 10, 2011 10:53 pm ]
Post subject:  Re: My First Carved Top
What a pleasing shape. [:Y:] A familiar single-cut mood with a hint of soloist.
Author:  Chris Pile [ Sun Jul 10, 2011 10:53 pm ]
Off to a good start!
Author:  Ommadon [ Sun Jul 10, 2011 10:58 pm ]
Thanks guys, does anyone have a good way to make the bowl type spots for the control knobs? I used a router cove bit bit in the drill press but was less then impressed. Im open to ideas.
Author:  Deegatron [ Mon Jul 11, 2011 8:43 am ]
Take a drill bit the same size as your holes for the pots....
drill thru a pice of 1" diameter wood rod....
glue the rod to the drill bit.... about 1/2 way up....
once glue is dry put the drill bit into the drill press and spin it....
use a rasp or sand paper on a block to shape the wood rod to any shape you'd like.
then glue small strips of sandpaper to the wood block... works like a charm and it's cheep... it'll really only cost you a drill bit..... + you can shape it any way you'd like... from a very soft U to a hard V with a flat on the bottom... anything goes....
