| Question about a router bit http://luthiersforum.com/forum/viewtopic.php?f=10123&t=35143 |
| Author: | jimmysux [ Fri Jan 27, 2012 4:18 pm ] |
| Post subject: | Question about a router bit |
Does anyone know where I can get a spiral cut flush trim but with the bearing on the bottom instead of the top? I would prefer a 1/4" shank but can do 1/2". I've been looking a lot an cant seem to find one. Any help would be appreciated. |
| Author: | theguitarwhisperer [ Fri Jan 27, 2012 5:37 pm ] |
| Post subject: | Re: Question about a router bit |
http://www.google.com/products/catalog? ... CHoQ8wIwAg Here's one. Don't know if it's the BEST place to get one, but they're available. |
| Author: | jimmysux [ Fri Jan 27, 2012 5:40 pm ] |
Thanks but that has the bearing on top, I'm looking for one on the bottom. Incidentally I have that exact bit already. It's a good bit! |
| Author: | WindyCityBluesBox [ Fri Jan 27, 2012 5:49 pm ] |
is it necessary for it to be spiral cut? what are you trying to do? |
| Author: | jimmysux [ Fri Jan 27, 2012 6:42 pm ] |
No special reason, I just like the cleaner cuts they produce |
| Author: | Mark Fogleman [ Fri Jan 27, 2012 7:24 pm ] |
![]() http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_solid.html#spiral_flushtrim_anchor No experience with this bit but it has what you want. Here's a different spin: ![]() http://www.amanatool.com/bits-fv/46192.html and another: ![]() http://www.amanatool.com/bits-fv/46300.html and another: ![]() http://www.amazon.com/RFT5200-CARBIDE-UP-CUT-SPIRAL-ROUTER/dp/B0012JI870 |
| Author: | jimmysux [ Fri Jan 27, 2012 7:38 pm ] |
I'm looking for one with a top guide bearing, like you use on a plunge bit |
| Author: | EWC&Son [ Fri Jan 27, 2012 7:47 pm ] |
Post 1: jimmysux wrote: Does anyone know where I can get a spiral cut flush trim but with the bearing on the bottom instead of the top? Post 7: jimmysux wrote: I'm looking for one with a top guide bearing, like you use on a plunge bit OK, Jimmy. You gotta make up your mind if we’re gonna help you.
| Author: | jimmysux [ Fri Jan 27, 2012 7:54 pm ] |
Yeah I got mixed up sorry, top guide bearing |
| Author: | Mark Fogleman [ Fri Jan 27, 2012 8:10 pm ] |
You could always turn your router upside down.
| Author: | VirgilGuitar [ Fri Jan 27, 2012 11:26 pm ] |
Actually everyone, Jimmy is PROBABLY looking for a SIDE-Bearing...
| Author: | B. Howard [ Sat Jan 28, 2012 8:08 am ] |
Spiral bits are mainly designed for CNC use and plunge cutting. Never seen one with the bearing between the shank and flutes. You could use this bit with a 1/2" shank and a 3/4" cut http://routerbitworld.com/Amana-46109-S ... 046109.htm Use it with a guide collar and you will get the same effect, just more trouble to set up and not as smooth, that is of course if you don't have coronary when you see the price on the bit. |
