Grain fill and dye technique
http://luthiersforum.com/forum/viewtopic.php?f=10123&t=37666
Author:  dzsmith [ Sat Sep 08, 2012 9:02 am ]
Post subject:  Grain fill and dye technique
Hi Fellows,
I'm planning way ahead on my next build.
I'm using Chinaberry that has open grain that I will need to fill.
I will use transtint water based dye.
I'm not sure how to go about filling grain when using dye.
I've used epoxy fill in the past with good results.
My thought is to apply the dye, apply the epoxy, and then try to sand it back leaving only the filled spots, then apply dye.
Perhaps I can add dye to the epoxy?
Any thoughts?
Here's a pic of Chinaberry I used on a build - I did not fill the grain on this one.
Dan
Author:  Stuart Gort [ Sat Sep 08, 2012 2:36 pm ]
Post subject:  Re: Grain fill and dye technique
I'd like to hear a detailed description of the process that you used to create this one. Primarily I'm interested on what was done to create the unique differentiation of green and brown coloring.
It could be relatively simple to combine this process with an epoxy pore fill....depends on what you did to get the color here.
Author:  klooker [ Sat Sep 08, 2012 4:56 pm ]
Yes, Transtint liquid will dissolve in epoxy - that's all I can help you with.
Kevin Looker
Author:  cphanna [ Sat Sep 08, 2012 6:07 pm ]
You have doubtless already seen the answer that comes up most often: Experiment on scrap and see what works for you.
Author:  dzsmith [ Sat Sep 08, 2012 8:20 pm ]
Hey Zlurgh, I just wiped on one coat of transtint dissolved in water. I was pleased to see some of the brown still showing.
DZ
Author:  dzsmith [ Sat Sep 08, 2012 8:26 pm ]
Here's a pic of the rough Chinaberry.
I reckon the dye was absorbed more easily in the softer grain.
DZ
