Neck-issues
http://luthiersforum.com/forum/viewtopic.php?f=10123&t=47120
Author:  Waldorf [ Fri Jan 22, 2016 10:12 am ]
Post subject:  Neck-issues
Greetings,
I had an old pacifica lying around, and as I am quite a DIY-guy, I wanted to try and make something out of it.
The paintjob had some cracks, so I decided to strip the paint and go for a natural-oil finish. So as I was sanding
my way to the basswood, I removed quite some layers (and millimeters). After quite some time sanding and finishing,
I decided to put my neck back in the pocket, to see that there is quita a height difference since I sanded the paint.
Now, my question is, should I remove some off the neck or some of the pocket. And is it safe the do it myself, or
can I screw the whole guitar up and should I get some professional luthier do it for me?
I'm from Belgium btw, please ignore my grammar mistakes
Author:  alan stassforth [ Fri Jan 22, 2016 8:23 pm ]
Post subject:  Re: Neck-issues
Hi Bert!
I think you'll be fine.
The bridge has a lot of adjustment for height,
and if that doesn't work,
you can shim the neck to tilt it the way it works.
Have fun!
Author:  Waldorf [ Sat Jan 23, 2016 4:16 am ]
Thanks for the tip, just found some spare strings, and with some adjustments, it worked. The action however is the lowest I've ever seen (which I like), bit the last 3 frets are unplayable because of fret-buzz, but I guess I can fix that with the trust rod.
Author:  Barry Daniels [ Sat Jan 23, 2016 10:55 am ]
The "truss" rod is only for setting the relief (slight forward bow) of the neck. Do not use it for setting string height.
Author:  Stuart Gort [ Tue Jan 26, 2016 10:53 am ]
Amen.
