| One or three piece neck? http://luthiersforum.com/forum/viewtopic.php?f=10123&t=50201 |
| Author: | Bill Braske [ Wed Jan 17, 2018 10:16 am ] |
| Post subject: | One or three piece neck? |
Ok, I've got the neck blanks for my next two builds (Thanks again, Hibdon Hardwood!), 2 neck-thru solid bodies. The boards are big enough to make the neck/center section of the body from one piece, but I imagine making it from 3 pieces will give it more stability. Here are my questions: If I rip it in three pieces, how do I re-orient that middle piece? Rotate it on its axis? flip it end for end, or both? Thanks again for all the help! |
| Author: | Lincoln Goertzen [ Wed Jan 17, 2018 5:11 pm ] |
| Post subject: | Re: One or three piece neck? |
What kind of wood? Might make a difference in the advice. If they're off quarter a bit, I might try for a /\/ appearance at the end grain. |
| Author: | Clinchriver [ Wed Jan 17, 2018 5:59 pm ] |
Bill Braske wrote: Ok, I've got the neck blanks for my next two builds (Thanks again, Hibdon Hardwood!), 2 neck-thru solid bodies. The boards are big enough to make the neck/center section of the body from one piece, but I imagine making it from 3 pieces will give it more stability. Here are my questions: If I rip it in three pieces, how do I re-orient that middle piece? Rotate it on its axis? flip it end for end, or both? Thanks again for all the help! Honduran Mahogany is very stable one piece should work fine. Same thing on the three piece orient them to where it looks its best. Good Luck |
| Author: | Bill Braske [ Thu Jan 18, 2018 10:27 am ] |
Huh, I guess I forgot to mention that it's honduran mahogany. One board is quartered really good, the other not as good. I may just do one of each... |
