Solely owned and operated by Lance Kragenbrink
It is currently Wed Feb 26, 2020 4:39 am
PostPosted: Sun May 26, 2019 1:49 pm
First name: David
Zip/Postal Code: 94558
I'm getting ready to set a Gibson style bridge at 24.74 scale length. Do you like to install the centerline of scale adjustments with an added compensation or just sent the bridge saddles at center assuming there is adjustability both ways on saddle adjustment?
https://www.instagram.com/dofthesea/
PostPosted: Sun May 26, 2019 3:10 pm
First name: Freeman
Last Name: Keller
You will never have "negative compensation", why waste saddle travel that you will never use. I use StewMac's calculator and it has never failed to provide adequate adjustment.
PostPosted: Sun May 26, 2019 4:55 pm
First name: David
I forgot about the Stew Mac fret scale. Thanks for the reminder. What offset have you used on the offset for legs of post?
PostPosted: Sun May 26, 2019 6:34 pm
First name: Freeman
Last Name: Keller
If your scale truely is 24.74 (there are several Gibson scales) the SM calculator says
24.811" (± 0.030") from nut to center of treble-side post. Mount bass-side post 1/16"-1/8" further from the nut.
That would work for me. I would also check to make sure the high E saddle at its farther forward position is at or slightly beyond the scale location.
You could also use R.M. Mottola's incredible calculator do dial it in perfectly for whatever strings you plan to use
https://www.liutaiomottola.com/formulae ... sation.htm
PostPosted: Sun May 26, 2019 11:26 pm
First name: David
Great link Freeman. You're a wealth of info.
