More Paduck Pics " Updated "
http://luthiersforum.com/forum/viewtopic.php?f=10128&t=30292
Page 1 of 2
Author:  WudWerkr [ Sat Dec 11, 2010 11:58 am ]
Post subject:  More Paduck Pics " Updated "
I am currently waiting on some Super Soft II I have ordered . After breaking the second side it became clear that a new route was needed . In the meantime I have done rough work on the top and back. There is still cleanup work to be done , however the basics are there.
Author:  Chris Oliver [ Sat Dec 11, 2010 12:03 pm ]
Post subject:  Re: More Paduck Pics
8-)
Author:  WudWerkr [ Sat Dec 25, 2010 3:38 pm ]
I have been working on the fretboard and getting it ready to fret . I have encased the fretboard in Cocobolo, the 1/4" Strip running down the neck is a vertical piece . The 1/8" thick piece under the fretboard as well as the binding all glued in place will/ should make for a fairly stable neck. I HOPE
The Cocobolo had more sapwood in it than I would have liked , However I dont believe that it will be to much of a factor. I am waiting to try and get some Padauk Dots for the fret board inlays . I may have to make them , but am looking around first.
Author:  Ti-Roux [ Sat Dec 25, 2010 4:25 pm ]
You should give a try to white glue, that dries clear... or even hide glue. Or maybe clean this glue before it get dry.
Author:  WudWerkr [ Sat Dec 25, 2010 5:02 pm ]
I am using titebond orig. I appreciate the suggestion , i guess im not sure where u are refering to in the post . the top and back inside ?
Author:  Ti-Roux [ Sat Dec 25, 2010 5:20 pm ]
I'm refering to the top. We see the yellow dried glue all along the braces. Once dried, Titebond is really a mess to clean up nicely. Clean it with hot wet rag when it's still fresh, it will save you a lot of trouble.
Author:  WudWerkr [ Sat Dec 25, 2010 9:01 pm ]
Thanks for the suggestion ! [:Y:]
Author:  WudWerkr [ Mon Jan 03, 2011 1:39 pm ]
Modified the fretboard a little , just to be different. And b4 anyone goes and starts accusing me of herasy , laughing6-hehe , I KNOW I have effectivly cut the playability to 16 frets ! pfft I wanted to Have a Little Different design than normal , cause face it , Im not normal ! laughing6-hehe Mounted the dots " Thanks Chris" and put in frets .
WHY IS IT That the very LAST fret wire installed is ALWAYS the one that tries and tears out ?? [headinwall]
Author:  Chris Oliver [ Fri Jan 07, 2011 8:27 am ]
Nice fret markers.. I didn't know if you would be able to see them. [:Y:]
Don't you dare glue that fretboard on there until you fix the fretboard... remove fret, dam groove, ac glue fill with dust, sand level, clear slot, new fret, no problem!
Author:  WudWerkr [ Fri Jan 07, 2011 9:26 am ]
To be honest Chris , I thought about taking it out and filling with glur and ebony dust , sanding flat and leaving it out . It isnt a playable fret anyway . I havent decided , It is glued in , and needs a lil more touch up .
Author:  Chris Oliver [ Sat Jan 15, 2011 6:55 pm ]
Did you get it out of there yet?
Author:  WudWerkr [ Sun Jan 16, 2011 6:26 pm ]
No chris I havent done anymore with it in tha last week or so , I have been buffing the pearblossom and I made the pickguard . I am going to finish it out I think B4 I go any further on this one . I need Quartersawn Padauk for sides . All I have is flawsawn and I have had no sucess in bending without breaking them . I will get back on it soon though.
Stop by the pearblossom thread and tell me what you think of my pick guard .
Author:  StevenWheeler [ Mon Jan 17, 2011 6:40 pm ]
WudWerkr wrote:
I need Quartersawn Padauk for sides . All I have is flawsawn and I have had no sucess in bending without breaking them.
Hey Jim,
Guess what i found yesterday. PM your address to me and I'll get this board in the mail to you.
Author:  Chris Oliver [ Wed Mar 02, 2011 10:59 pm ]
James.... what's going on here? The weather has stunk too much to be outside over the last month...
No pressure. pizza
Author:  WudWerkr [ Fri Mar 04, 2011 8:40 am ]
Thanks for the interest chris , [:Y:] actually I have a wife and teenage daughter and ( 1 ) bathroom ,soooooooooooooooooo lately ive been having to go to gas station to get any quality time in bathroom it seems gaah
I have been building a second bathroom im my basement , "just for dad" laughing6-hehe laughing6-hehe . Have cabinets in , tile laid and working on shower area .
I will be back in shop sooon and look forward to posting more on it soon !
Author:  WudWerkr [ Thu Mar 31, 2011 10:42 am ]
I have successfully bent the Padauk sides . gaah There are a few check marks I have to work on , but they are done. IF I EVER talk about building with this again someone shoot me !! laughing6-hehe . Actually its beautifull wood , just a pain to bend .
Author:  WudWerkr [ Mon Apr 04, 2011 11:58 am ]
Tried my hand at my first binding this weekend . I am sure I made several mistakes , but we shall see when its sanded . I used TiteBond Orig. to glue the binding . Is there a better choice? After the binding was set I set the neck and angle . Its held in right now by a drywall screw . I have found they work very well for the smaller Mando's .
Author:  Chris Oliver [ Mon Apr 04, 2011 11:04 pm ]
Lookin' good James.
I use the same glue although... .I use a lot of tape to hold the binding on as I go... and use the large rubber bands after complete.
Keep up the good work....
Author:  WudWerkr [ Tue Apr 05, 2011 7:45 am ]
Post subject:  Re: More Paduck Pics Update
I started sanding the binding and some of it came loose :o [headinwall] Sooooooooo I rerouted the edge and started over. This time using a thick CA and ALOT more clamping / rubberbands . Also I thinned my binding so that it was virtually flush and alot thinner .
We shall see if it sticks this time
Author:  Ian Cunningham [ Wed Apr 06, 2011 7:24 am ]
Love that headstock. Can't wait to see it finished.
Author:  WudWerkr [ Thu Apr 21, 2011 2:48 pm ]
Post subject:  Re: More Paduck Pics " Updated "
A few more pics of the Padauk Build Top is on , Back is on , Neck is set and the binding has been routed .
The Binding will be cocobolo to match the neck and headstock
Author:  fric [ Sat Apr 23, 2011 4:08 pm ]
:lol: laughing6-hehe laughing6-hehe laughing6-hehe
I know how are you feeling
Author:  Alexandru Marian [ Sat Apr 23, 2011 4:46 pm ]
At what thickness did you bend?
Author:  WudWerkr [ Sat Apr 23, 2011 6:38 pm ]
the sides are .075 thick and I bent with a bending iron [headinwall]
Author:  Alexandru Marian [ Sat Apr 23, 2011 6:55 pm ]
Thanks. Good to know as I have a set I might use in the near future. Very nice taptone - this wood seems to have a huge bang for the buck factor, although the color is kind of crazy.
Mine doesn't feel particularly dense and I was planing 0.08 but I might go thinner now.
