| newbi needs info on steam use http://luthiersforum.com/forum/viewtopic.php?f=10128&t=35570 |
| Author: | jim daniels [ Wed Feb 29, 2012 7:42 am ] |
| Post subject: | newbi needs info on steam use |
is there a set of plans for building a steam producer or what do I use to take the mandolin apart? I have a hand held torch or will a household steam iron work? thanks jim |
| Author: | Corky Long [ Wed Feb 29, 2012 8:30 am ] |
| Post subject: | Re: newbi needs info on steam use |
Do you have an old cappucino maker? They work perfectly - clamp a hose onto the "milk frother"attachment and you've got a steamer, perfect for loosening necks, etc. |
| Author: | Chris Oliver [ Fri Mar 02, 2012 4:24 pm ] |
+1 to what Corky wrote. I use the StewMac steamer tube and tip with my milk frother. StewMac hose/needle here Of course others have used a heat resistant tube from your local auto parts store and a basketball(or other ball) air needle. |
| Author: | Shaw [ Sat Mar 03, 2012 1:05 am ] |
I use a krupp espresso machine I picked up at a thrift store for $8. And I bought some high pressure hose at the car parts store and a football/basketball inflation needle and some small hose clamps. |
| Author: | Bob Matthews [ Sat Mar 03, 2012 8:08 am ] |
I use a wallpaper stripper, a flexible rubber hose with a needle from a football pump for doing neck resets, I'm sure it's overkill as the coffee maker sounds perfect, but it's what I had to hand when i did my first reset. I haven't had the need to use steam for anything else, but some luthiers will use it for gluing on backs and sides with hide glue. Here's an advocate. http://www.thestrad.com/pdfs/hamtradesecrets.pdf |
| Author: | ernie [ Sat Mar 03, 2012 8:50 am ] |
Some folks use special gloves when working with steam.I used them when bending long arm bows for making chairs.Steam burns are nasty.I speak from experience.
| Author: | Shaw [ Sun Mar 04, 2012 12:29 am ] |
Yeah Ernie is right about burns. I burned myself slightly when I first started experimenting with the espresso machine.I don't know if my gloves are special but I just wear these smooth leather work gloves that I have....Mike |
| Author: | Steve_E [ Sun Mar 04, 2012 12:34 pm ] |
I use my wife's Iron with the steam burst option. I know it doesn't get into all the little places, but I sure enjoy watching her freak out that I'm using her iron.
| Author: | dustyjeans [ Tue May 08, 2012 12:50 pm ] |
Old cappicino machine! if you really need steam. Personally i only use steam on delicate vintage insturments, or for neck removal. Mix up a glass of hot water, denatured alcohol, & a couple drops of dish soap and inject it into the seam with a syringe. Or wet the kerfing & glue from the inside. Im not talking about soaking it, just enough to soften the glue a bit. Take your time with a couple of disassembly knives (stew mac) or pallette knives from art supply store. Work slowly and watch where your tool is going. As always it's best to practice on a couple of junkers 1st. |
