| Tenor Uke bridge height and other questons. http://luthiersforum.com/forum/viewtopic.php?f=10128&t=40808 |
| Author: | Bryan Bear [ Fri Jul 05, 2013 2:55 pm ] |
| Post subject: | Tenor Uke bridge height and other questons. |
I'm working through my first ever uke, a tenor of my own design. I have the body made and am ready to layout the neck and fretboard. I want to use the fretboard thickness to help tweak the string height at the bridge but am not 100% clear on what the action height at the 12th fret should be my goal (this is the first time I have done anything with nylon strings). I would also like to know what the typical bridge height and saddle height are for these little buggers. I have a slight angle built into the top like I would for a steel string; I think I'm where I need to be, but if I am going to need to cheat a little now is the time. . . |
| Author: | the Padma [ Fri Jul 05, 2013 4:09 pm ] |
| Post subject: | Re: Tenor Uke bridge height and other questons. |
Yo, Bryan Cheating not allowed. The information you are requesting has been deleted from me memory banks andan, Official Class D, lever 7 clearance is needed to obtain this info on the OLF Go here http://ukuleleunderground.com/ sign up, do not confess to knowing me, make a donation and ask your question again.................................................... blessings ..... ........?adma |
| Author: | Bryan Bear [ Fri Jul 05, 2013 4:38 pm ] |
I'm a bad liar, what if they ask if I know you? Change the subject? |
| Author: | Quine [ Sat Jul 06, 2013 8:36 am ] |
I set my action at 0.09" at the 12th fret. Thats kinda mid-high action for a tenor. It really depends on the player though...some strum hard and want high action, some finger pick and want lower. I try to leave about 3/16" saddle above the bridge so the action can be lowered easily. |
| Author: | Bryan Bear [ Sat Jul 06, 2013 1:10 pm ] |
Thanks Kevin, just the ku d of numbers I wanted. I start with an I between saddle height. This is getting donated so I don't know what the owner will prefer, better to give them some wiggle room. |
