| msween's entry http://luthiersforum.com/forum/viewtopic.php?f=10134&t=39367 |
| Author: | msween [ Sat Feb 16, 2013 7:59 am ] |
| Post subject: | msween's entry |
I figured I might as well jump, provided solidbody electrics aren't disqualified. I've completed building one guitar so far in my life, just recently. THis will be my build number 2.5, since I started a les paul copy some years ago, and have never had the know how to carve the top, so I put it on the back burner until I get some more experience. My plan is to build a carved top, neck through super-strat style guitar, mahogany neck and body, ebony board. smaller baritone scale, 27", with a tune-o-matic/string-through-body bridge. This will be my first attempt at carving a top, binding a guitar, radiusing and slotting my own fret board, having a neck angle, and finishing in something other than tung oil. I have all the mahagony ready to go, just waiting on some fingerboard blanks to show up in the mail from A&M wood specialty. I should also add, that this is my last build in which I plan to use premade pickups, as I have a nice set bill Lawrence l-500's to throw in her. After this I plan to start winding my own. |
| Author: | WudWerkr [ Sat Feb 16, 2013 8:41 am ] |
| Post subject: | Re: msween's entry |
You are added to the list and I look forward to seeing your work
| Author: | msween [ Mon Feb 18, 2013 12:52 pm ] |
Thank you! Wondering if someone could give me some advice about calculating my neck angle with the 27" scale and a tune-o-matic bridge, with it being neck through. would you stay with the standard les paul angle, or does the longer scale length make you're neck angle different (I'm picturing a smaller angle?)? |
| Author: | ZekeM [ Mon Feb 18, 2013 2:50 pm ] |
Scale shouldn't effect the angle at all. You won't see enough difference to matter IMO. If you are running a 2 degree angle and you extend the scale by 2" you will only see 1/32" of difference of height. With a tune-o-matin you have a lot more adjustment than that. |
| Author: | ZekeM [ Mon Feb 18, 2013 3:12 pm ] |
If you would like the formula to calculate a specific neck angle according to a desired bridge height it is SIN A=(h-f)/d With A being your angle, h being height of bridge, f being the thickness of the fretboard (or the height of the neck above the body at the neck/body joint), and d being the distance from the neck/body joint to the bridge. I hope that made sense |
| Author: | msween [ Mon Feb 18, 2013 3:14 pm ] |
So would you recommend going with a 2 degree angle? My first build I went with a recessed Floyd, so I didn't need an angle at all, thus the hesitation with this. with a neck through, do you start your angle where the fretboard ends, or where the body join starts? |
| Author: | ZekeM [ Mon Feb 18, 2013 3:25 pm ] |
I'd start by measuring your tune o matic and deciding what the height you need from the body to the top of the saddles. Leaving room for adjustment both up and down. That will give u a reference of what you need to achieve. That is what ultimately determines your angle. Well that and thickness of the fretboard. Ive never done a neck through before but I would presume that starting the angle at the end of the fb would be the correct way to go about it. |
| Author: | PeterF [ Mon Feb 18, 2013 5:25 pm ] |
ZekeM wrote: If you would like the formula to calculate a specific neck angle according to a desired bridge height it is SIN A=(h-f)/d With A being your angle, h being height of bridge, f being the thickness of the fretboard (or the height of the neck above the body at the neck/body joint), and d being the distance from the neck/body joint to the bridge. I hope that made sense Shouldn't f be the height of the strings above the body at the neck/body joint? Because it's the string height that changes as the angle changes - all the other things stay the same. Edit: that would actually give you the angle of the strings. You would then have to do SIN a=H/d where H is action height above the 12th fret. Then do 'little a minus big A' to give the neck angle. |
| Author: | ZekeM [ Mon Feb 18, 2013 7:49 pm ] |
PeterF wrote: ZekeM wrote: If you would like the formula to calculate a specific neck angle according to a desired bridge height it is SIN A=(h-f)/d With A being your angle, h being height of bridge, f being the thickness of the fretboard (or the height of the neck above the body at the neck/body joint), and d being the distance from the neck/body joint to the bridge. I hope that made sense Shouldn't f be the height of the strings above the body at the neck/body joint? Because it's the string height that changes as the angle changes - all the other things stay the same. Edit: that would actually give you the angle of the strings. You would then have to do SIN a=H/d where H is action height above the 12th fret. Then do 'little a minus big A' to give the neck angle. Yeah that would give you the strings. the formula i gave should calculate the angle for the actual neck. But a tune o matic has plenty of adjustment up and down anyway so it doesnt have to be extremely precise anyhow. Peter you are such a math geek
| Author: | PeterF [ Tue Feb 19, 2013 3:22 am ] |
| Author: | msween [ Sun Mar 03, 2013 10:18 am ] |
![]() this is the bridge I plan to use on my build, but looking at the rollers where the strings will break over, the slots seem quite narrow, especially where this is a baritone build, and will likely be using a string gauge of 0.014-0.063" or so. I've never used a roller bridge before, so I'm not sure what to expect. the slots seem too narrow for even a standard string gauge set. Should I rethink my bridge options, or go ahead with this? Would it be likely to give me issues? I certainly wouldn't mind dropping a floyd in there instead, but I always seem to prefer floyds with more standard scale lengths, and tune-o-matic with longer baritone scale. I liked this bridge in particular because the bridge piece itself locks onto the posts, which in theory should increase sustain and tone over all. I can get a traditional style tone-pros, but there`s a huge difference in price between those and what I`ve got here. Most likely a tonepros would be better quality materials, this one is zinc I believe. and the finish quality on this leaves a lot to be desired. it`s chipping away in a couple spots and it has never even been installed on anything... |
| Author: | Rodger Knox [ Tue Mar 05, 2013 6:22 pm ] |
You really don't need any neck angle, depending on how you want to do it. The really important thing is the height of the strings above the top at the bridge. With that bridge, I'm guessing the string height will need to be about 5/8". Take that number and subtract the thickness of the fretboard (1/4") and a little for the action (1/16"), which leaves you with another 5/16". If you make the strings parallel to the top (no neck angle), then you need to cut the neck so that the bottom of the fretboard will be 5/16" above the top. If you angle the neck, the angle will be arctan(5/16" / distance from end of fretboard to bridge), and the bottom of the fretboard will be flush with the top of the body. You can also do a combination of the two, with some neck angle and some height between the top of the body and the bottom of the fretboard. The best way to work this out is to draw a side view. I've done it both ways, other factors come into play. If you have a truss rod and want the adjustment at the heel, leaving some space between the fretboard and the top works nicely, you don't have to remove a pickup to adjust the rod. |
| Author: | Alex Kleon [ Tue Oct 15, 2013 6:02 pm ] |
Looking good, Mark! How are you planning to finish the guitar? Stain, plain or maybe a 'burst? Alex |
| Author: | msween [ Wed Oct 16, 2013 7:32 pm ] |
Thanks Alex! My original plan was black stain with blue grain filler, but my scrap tests are coming out pretty crappy. My biggest struggle with my builds so far has been the finish, I think it would look sweet with the burst, but my confidence in successfully spraying or hand-rubbing a burst is not very high, lol. I'm going to take a couple more rounds of testing my black stain with colored filler, but if I can't get it right on scrap, I may just "ebonize" it. I think my issue is trying to tint the filler thoroughly, I make it too runny, and I end up with small pieces of filler that haven't gotten stained. On my first attempt, the black was gorgeous, then I applied my filler, which actually came out Olive Drab. when I sanded it back to reveal what I hoped was a nice greenish version of a Gibson VooDoo, the whole surface had stained this ugly green over the black, and I'd sanded through to the mahogany with a very light sanding with 500grit paper. I may also not be letting my dye sit long enough before I rub off the excess. hard to say. Times running out though! |
